Cut out?
Cut out? BGP 23 Jan 18:05
  Cut out? Martin Nordholts 23 Jan 18:09
   Cut out? BGP 23 Jan 19:52
BGP
2010-01-23 18:05:11 UTC (over 15 years ago)
Cut out?
I have an image that I want to cut a part out of to use as a separate image. The shape of the area I want to cut out and use is irregular. How can I cleanly cut out that part and copy it as a seperate image?
Martin Nordholts
2010-01-23 18:09:27 UTC (over 15 years ago)
Cut out?
Select the part you want to copy, then Edit -> Copy, then Edit -> Paste as -> New Image
To select irregular shapes, try the Free Select Tool and the quick mask.
/ Martin
BGP
2010-01-23 19:52:02 UTC (over 15 years ago)
Cut out?
Thanks....that helped.
Here's what I did (using GIMP ver. 2.6.8)
1. Clicked "Scissors Select Tool"
2. Traced the outside of the object I wanted.
3. Clicked "Edit -> Copy
4. Clicked "Edit -> Paste as -> New Image
/ Martin
