Plugins
Plugins BGP 23 Jan 03:39
  Plugins jolie 23 Jan 04:21
  Plugins Claus Cyrny 23 Jan 08:38
BGP
2010-01-23 03:39:33 UTC (over 15 years ago)
Plugins
I've noticed there are a lot of plugins that are available for GIMP.
Say for example you find a gradient plugin.
Where do you install it?
2010-01-23 04:21:38 UTC (over 15 years ago)
Plugins
Go to edit - preferences - folders.
There you see the path to the folders where you can put gimp resources in. These are just folders on your computer. In preferences you can see where on your computer they are.
A gimp brush file should be put in the brushes folder, note that photoshop brushes can be used too.
A gimp script, (a file that ends with .scm )should be placed in the scripts folder, a plug-in, or python script in the plug-in folder, a gradient file in the gradients folder etc etc.
Claus Cyrny
2010-01-23 08:38:15 UTC (over 15 years ago)
Plugins
Where do you install it? _______________________________________________ Gimp-user mailing list
I can strongly recommend "Grokking the Gimp" by Carey Bunks. I guess this will answer about any of your question.
You can find it here:
http://gimp-savvy.com/BOOK/index.html
HTH,
Claus
