Hot plug-in disabled
Hot plug-in disabled Tom Ball 15 Feb 08:10
  Hot plug-in disabled Carol Spears 15 Feb 09:16
  Hot plug-in disabled Sven Neumann 15 Feb 10:27
Tom Ball
2004-02-15 08:10:12 UTC (about 21 years ago)
Does anyone know why the Plug-ins->Color->Hot menu item is disabled? I'm working on an RGB image which its source says is required. Any help would be appreciated.
Tom
___________________
Carol Spears
2004-02-15 09:16:04 UTC (about 21 years ago)
Tom
can you be a little more specific as to where this menu is located?
there are other reasons than image mode that a plug-in does not work. perhaps the plug-in wants to work on a "background" layer -- which is a layer without alpha.
i must admit, i have never seen this plug-in nor that location in any of the menus; however, i haven't updated my gimp in a few days.
2004-02-15 10:27:07 UTC (about 21 years ago)
TomBall@netscape.net (Tom Ball) writes:
As shown by Plug-In Details (as found in the Xtns menu), this plug-in (->Filyers->Colors->Hot), needs an RGB drawable and doesn't handle RGBA. So you will probably have to flatten your image first.
