help files?
help files? Corasande@cs.com 10 Feb 13:53
  help files? Jonathan Chetwynd 10 Feb 16:26
  help files? Sven Neumann 10 Feb 19:55
help files? Michael Schumacher 10 Feb 21:20
  help files? Sven Neumann 10 Feb 22:09
Corasande@cs.com
2004-02-10 13:53:34 UTC (about 21 years ago)
help files?
At the moment most of GIMP is over my head, so I was trying to look up something in the help files, but I get an error message:
Could not find the GIMP Help Browser procedure. It probably was not compiled because you don't have GtkXmHTML installed
Then there are buttons for "Use Netscape instead" and Cancel.
Netscape is not installed on this computer which has windows 98, using GIMP version 1.2.5. I'm lost and don't understand what this means.
Thanks Sandy
Jonathan Chetwynd
2004-02-10 16:26:01 UTC (about 21 years ago)
help files?
Sandy
http://www.gimp.org/docs.html may be what you want
thanks
Jonathan Chetwynd http://www.peepo.co.uk
"It's easy to use"
2004-02-10 19:55:13 UTC (about 21 years ago)
help files?
Corasande@cs.com writes:
IIRC, GIMP on Windows uses IE even though the GUI says Netscape. There used to be a bug report about this. Did you try to click the "Use Netscape" button?
2004-02-10 21:20:38 UTC (about 21 years ago)
help files?
GIMP on Win32 uses the systems default browser. Which, IMHO, should never be IE unless you know what you're doing ;)
HTH, Michael
2004-02-10 22:09:39 UTC (about 21 years ago)
help files?
"Michael Schumacher" writes:
Good point :)
