two bizarre problems
2 of 3 messages available
two bizarre problems Olivier Lecarme 19 Jan 18:15
  201001191823.52990.tneuer@i... Torsten Neuer 19 Jan 18:23
   two bizarre problems Olivier Lecarme 19 Jan 19:08
Olivier Lecarme
2010-01-19 18:15:40 UTC (almost 16 years ago)
Dear GIMP users and developers,
I'm encountering two weird problems with GIMP recently. What is weird is that it's not the same on two different but similar computers, running the same versions of GIMP (2.6 or git 2.7) on the same version of Debian GNU/Linux (testing).
1. Any dialog like the ones obtained with most filters should contain small icons in the bottom buttons (Help, Reset, Cancel, and OK). This is the case on computer A, but not on computer B. This is consistent across all the dialogs.
2. The gtkam-gimp package is installed on both computers. There are two entries dealing with the camera in the Image: File -> Create menu on computer A, but none on computer B.
I did not yet discover any other difference, but maybe somebody could suggest me to explore some other parts. Of course I can make any additional suggested test for debugging this problem, which most probably comes from my installation on computer B, and not from GIMP itself.
Thanks in advance for any suggestion.
Olivier Lecarme
2010-01-19 19:08:46 UTC (almost 16 years ago)
I would assume that you are using two different Gtk+ themes on the computers.
No, it's the same (Glossy).
