Scissor problems pre2.0
Scissor problems pre2.0 Timothy E. Jedlicka - wrk 08 Feb 22:51
  Scissor problems pre2.0 Sven Neumann 08 Feb 23:17
2004-02-08 22:51:31 UTC (about 21 years ago)
I'm having trouble with Scissors (Select Shape from Image) in Pre2.0. Sometimes I can close the selection with a shift-click on the beginning point, then click in the middle of the outline and I get the marching ants. But other times I try to Shift-click to close the path(?) then click in the middle, and it draws another segment instead of turning my outline into a selection. What am I doing wrong? Is there a way to consistently close a scissor path and turn it into the selection?
Timothy Jedlicka, bonzo@lucent.com, 1-630-713-4436, AOL-IM=bonzowork Network Entomologist, Lucent Technologies, Testers For Hire
2004-02-08 23:17:57 UTC (about 21 years ago)
"Timothy E. Jedlicka - wrk" writes:
You don't need to Shift-Click, a simple click in the right spot does the trick. Then, watch the cursor. If you managed to close the shape, the cursor will not show a + sign if inside the shape and the forbidden sign when outside the shape.
Yes, I admit this could be improves. Patches to improve iscissors are of course very much welcomed.
