Behaviour of "gimp-layer-create-mask" with channels
Behaviour of "gimp-layer-create-mask" with channels Gino D 10 Jan 11:51
  Behaviour of "gimp-layer-create-mask" with channels Sven Neumann 10 Jan 12:08
Gino D
2010-01-10 11:51:37 UTC (almost 16 years ago)
Hi.
I need some clarification on how the Script-Fu procedure "gimp-layer-create-mask" acts with channels.
Supposing that the current image holds more than one channel, whether I wanted to call such procedure with its second argument "mask-type" set to "ADD-CHANNEL-MASK" (6) , how would the Script-Fu interpreter understand which channel to consider? Or rather, with what additional command should I specify the chosen channel?
2010-01-10 12:08:25 UTC (almost 16 years ago)
If in doubt, read the source code:
layer_cmds.c (layer_create_mask_invoker):
if (mask_type == GIMP_ADD_CHANNEL_MASK) {
channel = gimp_image_get_active_channel (image);
The procedure will use the active channel. You can set the active channel using gimp-image-set-active-channel().
