problem modifying selection
problem modifying selection andrewandrew 08 Jan 22:04
  problem modifying selection Owen 08 Jan 22:18
  problem modifying selection Claus Cyrny 08 Jan 22:43
   problem modifying selection andrewandrew 09 Jan 19:07
2010-01-08 22:04:34 UTC (over 15 years ago)
I have trouble sometimes modifying the selection -- the new selection replaces the old instead of modifying it. Also, the selection marks become invisible.
-- using the modifier keys or the selection mode menu, and using any of the selection tools -- doesn't help
-- selection should be visible according to view menu, but it isn't -- the only way I can get back to normal is save and restart gimp
Either I've entered some select-unfriendly mode, or there's a bug. Help? thanks
gimp version 2.6, Ubuntu.
Owen
2010-01-08 22:18:59 UTC (over 15 years ago)
thanks
Hi
Make sure you have the tool options available . pick your select tool
. note in the Tool Options, Mode
. Replace
. Add
. Subtract
. Intersect
So make your selection then modify using the mode options
See http://docs.gimp.org/2.6/en/gimp-using-selections-add.html
Claus Cyrny
2010-01-08 22:43:15 UTC (over 15 years ago)
Hi Andrew,
inside the "Tool" options, there's the possibility to set different modes for
selections, such as 'Add', 'Subtract', etc. By checking the respective icon, you can add to or subtract from the current selection. If the selection "disappears", just press CTRL+T. This should bring the selection back, unless you accidentally removed the selection. Sometimes I made the experience that CTRL+T doesn't work for some reason. Then 'View > Selection' brings the selection back.
HTH,
Claus
2010-01-09 19:07:42 UTC (over 15 years ago)
thanks @owen and @claus, but this isn't the problem. I know about the different modes and use them a lot. This is something that sometimes happens, and I don't know if I'm accidentally pressing something.
As to ctrl^T, that's not it, because it's not about the visibility of the selection, it's about the selection itself. The selection actually disappears and is replaced by the new one, whichever mode I use, and whichever selection tool I use. (it's easy to tell what the selection is by pressing ctrl^comma and seeing the extent of the fill, even when the marquee is invisible)
The funny thing is that it happens only sometimes. Could it be a bug?
Hi Andrew,
replaces
invisible.
the
icon,
HTH,
Claus
