GIMP and transparency
GIMP and transparency Rick Duley 08 Jan 05:52
  GIMP and transparency Owen 08 Jan 06:05
  GIMP and transparency David Gowers 08 Jan 06:16
   GIMP and transparency Rick Duley 09 Jan 08:58
  GIMP and transparency Bob Long 08 Jan 06:20
Rick Duley
2010-01-08 05:52:39 UTC (almost 16 years ago)
I've been poking around manuals and such in GIMP but I cannot find the magic word.
I'm not a computer graphics geek - not by any standards - so I just refer to the functionality I need as "transparency". I need a GIF file with a transparent background. I assume GIMP can handle it, but would someone please tell me where the necessary information to do so is cloistered,
Thanks
Owen
2010-01-08 06:05:17 UTC (almost 16 years ago)
Layers dialog has an opacity slider. Windows->Dockable Dialogs->Layers
play with that
David Gowers
2010-01-08 06:16:02 UTC (almost 16 years ago)
Thanks
Owen's information is unrelated to what you want, assuming you mean total transparency. (if you mean partial transparency, GIF doesn't support it -- PNG does, though)
First, The layer must have an alpha channel. Right click on the layer in the layers dialog and select 'add alpha channel'. If it's grayed out, it already has an alpha channel.
Second, you must cut out the areas you want to be transparent. If you are trying to do color-keying, the 'select by color' tool will probably be helpful (followed by Edit->Clear to clear the area)
You can then export a GIF (or save one, depending on whether you are using a new or old version of GIMP)
Bob Long
2010-01-08 06:20:28 UTC (almost 16 years ago)
Thanks
Layer|Transparency|Add Alpha Channel
Delete areas you want to be transparent.
Rick Duley
2010-01-09 08:58:26 UTC (almost 16 years ago)
Thanks David and Owen
I think I have a lot of work to do to get up to pace with this package.
Thanks
