script-fu without display problem
script-fu without display problem Irek S?onina 05 Feb 23:51
  script-fu without display problem Sven Neumann 06 Feb 12:39
   script-fu without display problem Irek Slonina 06 Feb 12:59
    script-fu without display problem Sven Neumann 06 Feb 13:34
Irek S?onina
2004-02-05 23:51:58 UTC (about 21 years ago)
I have wrote a small script-fu script to be run by the web, but I have encountered a problem. Script lookes like this:
(define (script-fu-xcf2gif infile outfile) (let*
(img (car (gimp-file-load 1 infile infile))) (drawable (car (gimp-drawable-get-image img))) )
(gimp-image-flatten img)
(gimp-image-convert-indexed img 1 0 256 0 1 "") (file-gif-save 1 img drawable outfile outfile 1 0 0 0) )
which I am running from console like this: gimp -d -i -b '(script-fu-xcf2gif "blokada.xcf" "blokada.gif")' '(gimp-quit 1)'
and it produces something like this: This is a development version of The GIMP. Debug messages may appear here.
gimp_composite: use=yes, verbose=no +mmx +sse +sse2 -3dnow -altivec -vis (gimp:13064): Gtk-WARNING **: cannot open display: (gimp:13061): Gimp-Plug-In-WARNING **: gimp: plug_in_flush(): error: Broken pipe
(gimp:13061): Gimp-Plug-In-WARNING **: plug_in_close: plug-in aborted before sending its procedure return values GIMP: Plug-In crashed: "gif"
(/usr/lib/gimp/1.3/plug-ins/gif)
The dying Plug-In may have messed up GIMP's internal state. You may want to save your images and restart GIMP to be on the safe side. batch command: experienced an execution error. (gimp:13061): Gimp-Plug-In-WARNING **: plug_in_close: plug-in aborted before sending its procedure return values
The same code is executed successfully when run from xterm... I have also tried to make a display with Xvfb, but 1.3 theoritically does not need it, --display switch with combine with -i is marked as incorrect.
I am using gimp-2.0pre3.
2004-02-06 12:39:12 UTC (about 21 years ago)
Irek S?onina writes:
This script can only work accidentally. Have a look at this line:
Here you are accessing an image as if it was a drawable and then assign the image return value to a variable that is used as a drawable later.
I am sorry but I cannot reproduce this. If you can make up a simple and reproducable test case, please feel free to file a bug report.
Irek Slonina
2004-02-06 12:59:13 UTC (about 21 years ago)
I am a newbie in script-fu, I haven't understood my fault. I admit, I have passed over the drawable chapter. What is the right thing to do, when I want to get a useable drawable, that can be passed to file-gif-save function?
Ok, thanks.
br.
2004-02-06 13:34:42 UTC (about 21 years ago)
Irek Slonina writes:
(gimp-image-get-active-drawable image) should do the trick but it would be even better to simply use the return value of (gimp-image-flatten image).
