another prob with parasites and script-fu
another prob with parasites and script-fu Irek S?onina 05 Feb 23:30
  another prob with parasites and script-fu Sven Neumann 06 Feb 12:23
   another prob with parasites and script-fu Irek S?onina 06 Feb 12:49
    another prob with parasites and script-fu Sven Neumann 06 Feb 13:23
Irek S?onina
2004-02-05 23:30:01 UTC (about 21 years ago)
My previous problem with parasites in script-fu has dissapeared in new pre3 version (thanks Sven for URL to bugreport), but now I have one another: I tried to define "gimp-comment" parasite as defined in devel-docs/parasites.txt as PERSISTENT, but this causes an execution error of the script, as well as other defines commented below, with which I have tried to run the script:
(define (script-fu-xcf2gif infile outfile) (let*
(img (car (gimp-file-load 1 infile infile))) (drawable (car (gimp-drawable-get-image img))) ; (parasite (list "gimp-comment" GIMP_PARASITE_PERSISTENT "some comment")) ; (parasite (list "gimp-comment" IMAGE_PERSISTENT "some comment")) ; (parasite (list "gimp-comment" PERSISTENT "some comment")) (parasite (list "gimp-comment" 1 "some comment")) )
(gimp-image-flatten img)
(gimp-image-parasite-detach img "gimp-comment") (gimp-image-parasite-attachi img parasite) (gimp-image-convert-indexed img 1 0 256 0 1 "") (file-gif-save 1 img drawable outfile outfile 1 0 0 0) )
from libgimpbase/gimpparasite.h: #define GIMP_PARASITE_PERSISTENT 1
so I have tried to use direct the value of it instead of define, this works (script is executed successfully) but comment is not saved in gif:
[ireks@brightstar ufki]$ identify -verbose blokada.gif|grep comment [ireks@brightstar ufki]$
Is this a bug or am I doing something wrong? If I should rather go to gimp-devel or somewhere else group please let me know.
br.
2004-02-06 12:23:10 UTC (about 21 years ago)
Irek S?onina writes:
Uhm, what makes you think that you can construct a parsite using (list...) and why do you omit the data length? This can hardly work but I am afraid I cannot point you to a working example of using parasites from Script-Fu. I am not sure if this has ever been done successfully.
Irek S?onina
2004-02-06 12:49:51 UTC (about 21 years ago)
I was thinking, that it is a simple list, I haven't found any *parasite-new or something like this function in pdb db browser. There is some other method to do this?
like this: (parasite (list "gimp-comment" 1 14 "some comment")) ? because it makes an execution error when I'm trying to attach parasite with additional length field, value of length does not matter, the same with any other value, bigger or smaller.
Ok, thanks... after all I can use ImageMagick to add a comment.
br.
2004-02-06 13:23:38 UTC (about 21 years ago)
Did you look at the bug report I pointed you to recently? It has some example code that might work.
