Start Up Troubles
Start Up Troubles RoninSensei 13 Dec 17:44
  Start Up Troubles Leonard Evens 13 Dec 19:24
Start Up Troubles Jernej Simon?i? 13 Dec 19:37
  Start Up Troubles RoninSensei 13 Dec 22:22
   Start Up Troubles RoninSensei 13 Dec 22:49
2009-12-13 17:44:06 UTC (over 15 years ago)
Start Up Troubles
I just downloaded GIMP 2 last night and after installing it, I gave it a whirl. It pops up a near endless series of messages that read: "The Procedure entry point g_return_if_Fail_warning could not be located in the dynamic link library libglib-2.0-0.dll.
I tried renaming/removing the file but nothing has changed. Anyone know what could be wrong? I have windows Vista by the way.
Leonard Evens
2009-12-13 19:24:32 UTC (over 15 years ago)
Start Up Troubles
The Windows version of gimp should come with the appropriate library, but it may be that it isn't using it, but rather a previous version. See
old.nabble.com/gimp-2.6.4-i686-setup.exe-win-gimp-td21490905.html
Jernej Simon?i?
2009-12-13 19:37:18 UTC (over 15 years ago)
Start Up Troubles
Don't rename/remove the file that was installed by the installer, but the file that was dropped in your Windows\System32 directory by some broken program.
2009-12-13 22:22:55 UTC (over 15 years ago)
Start Up Troubles
what
Thanks to both of you for your suggestions. I tried everything and got
frustrated enough to uninstall it and reinstall. It starts up fine now. I will have to use it for a bit to see if anything else comes up. Once again, thanks.
2009-12-13 22:49:50 UTC (over 15 years ago)
Start Up Troubles
what
will
thanks.
Ok, the woes start again. I now get the same message, but with these:
Plug-in crashed: "file-jpeg.exe" (C:\Program Files\GIMP-2.0\lib\gimp\2.0\plug-ins\file-jpeg.exe)
The dying plug-in may have messed up GIMP's internal state. You may want to save your images and restart GIMP to be on the safe side.
Opening 'C:\Users\AJ\Pictures\Me, Myself, I and Pals\1Jen huge smile.jpg' failed:
Procedure 'file-jpeg-load' returned no return values
Help!
