How to apply rotation to a pattern?
2 of 3 messages available
How to apply rotation to a pattern? Marc Carson 09 Dec 20:36
4B2000ED.6080903@gmail.com 07 Oct 20:20
  How to apply rotation to a pattern? Marc Carson 09 Dec 21:07
Marc Carson
2009-12-09 20:36:18 UTC (over 15 years ago)
Is there a way to apply rotation to a pattern when it is used? For example, if I like a pattern but need to rotate it 30 degrees or so when it is applied to the selection.
Any help here would be appreciated.
Marc
Marc Carson
2009-12-09 21:07:04 UTC (over 15 years ago)
When you select your pattern, press SHIFT+R. Then you can rotale the pattern either clockwise
or counterclockwise. You can choose between adjusting the angle by hand, or by numeric value.
Do you mean when I select the pattern in the Patterns palette? Shift+R there doesn't seem to do anything.
I tried it on a selection within an image, but this is the normal rotation tool. How would that work for a pattern anyway? Can you demonstrate?
Thank you,
Marc
