GIMP 2.6.7 Design
GIMP 2.6.7 Design Jennifer Mohr 28 Nov 14:23
  GIMP 2.6.7 Design Greg Chapman 28 Nov 14:43
  GIMP 2.6.7 Design Patrick Horgan 28 Nov 19:33
  GIMP 2.6.7 Design Alexandre Prokoudine 28 Nov 22:56
Jennifer Mohr
2009-11-28 14:23:15 UTC (over 15 years ago)
GIMP 2.6.7 Design
After quite some time, I finally updated my GIMP from my beloved 2.4.7 to 2.6.7. Upon starting up the new GIMP I saw the new design that GIMP now had. I found that GIMP was much, much hard to use and made things much more frustrating.
Why you ask? Multiple reasons actually. Here are just a few of my HUGE dislikes about the new GIMP.
1] The main GIMP Tool page over laps every other page. You can not put it behind the other pages like you could before. Not to mention that it keeps getting in the way!!! Its so annoying because I can't move it and if I accidentally maximize it then I can't make it smaller again so I can't save my material!! I end up having to start all over again!!
2] There's no main menu (File, Tools, Edit, etc, etc) at the top of the GIMP Tool page. I can't open files, start new files, open the layers or brush pages. I have to go to one of my already opened files to do this. Its really annoying!
Is there any way to fix these problems in one of the up and coming versions of GIMP or is GIMP just crap now? I mean, this is making me HATE GIMP and that's saying a lot when its coming from me. I LOVED GIMP, more then any other program and I've tried just about every program in the book. I've never found another program as great as GIMP. Why would they ruin it like this? I'm starting to hate GIMP now. :(
Is there a way to fix these problems, does GIMP intend to do something or am I just screwed? :( This is really upsetting...please help!!
Greg Chapman
2009-11-28 14:43:07 UTC (over 15 years ago)
GIMP 2.6.7 Design
Hi Jennifer,
You can always go to EDIT > PREFERENCES > WINDOW MANAGEMENT and change the window behaviour. The new default is "Utility Window". Change it back to "Normal Window".
However, it is much better is to get used to the new type and use the TAB key to make the toolbox disappear. REcover the Toolbox with another TAB keystroke, while the Image window has focus.
It's now on the Image window - far more sensible and conventional!
Course you can! Use the conventional Open dialogue, accessed from the FILE menu on the new Main window or Image Window should you already have an image open, or simply drag and drop the file you wish to edit on to "Wilber's Eyes", either on the Toolbox or the Main window. Couldn't be easier!
I confess I've customised my GIMP so that these dialogues are now docked in the bottom half of the Toolbox - but it really is up to you how you customise the proram. Why not experiment a little to find a way to work that suits you best!
Rubbish! Just customise the GIMP to the way you want it!
Greg Chapman http://www.gregtutor.plus.com
Helping new users of KompoZer and The GIMP
Patrick Horgan
2009-11-28 19:33:42 UTC (over 15 years ago)
GIMP 2.6.7 Design
Oh, Jennifer, I'm sorry that this hit you like this. You are not alone. There was HUGE discussion on this list when it happened and many expressed exactly the same frustrations as you.
You can fix the first just by hitting the key. That makes your toolbox and layers dialog disappear giving you uncluttered access to your image. It turns out, after you get used to it, that it's better this way. The toolbox gets in the way less because you make it disappear, but it's more convenient because when you hit again it's right on top where you can get to it. Before people would lose their toolbox behind and have to hunt for it.
For the second issue, i.e. the menu's left the toolbox, that is because working without the toolbox window makes it more convenient to have the menus on the image window. That's also the reason that if you close your last image you get the blank window (almost blank, Wilbur's still there and you can drag and drop an image onto him.
I think you'll find, after your habits get trained that this is actually better/easier/more productive, but I'm with you. It was tremendously annoying for a few days, then I decided they were geniuses.
Patrick
2009-11-28 22:56:50 UTC (over 15 years ago)
GIMP 2.6.7 Design
Well, think about it from a different angle: before, when you closed the last image, all you had were just two thin floating dockers, so you had to drop a new image on just one of them and exactly in the right place. And on systems where windows of these dockers were utility windows, you would have a tough time looking for these dockers, because, believe or not, these windows were not listed in the windows pager. So now you have a whole window that solves exactly this issue. Besides, this window is just a first step to upcoming optional single-window mode.
Alexandre
