Urgently need to adjust photograph size
18 of 18 messages available
Urgently need to adjust photograph size Ruthy 17 Nov 17:28
  Urgently need to adjust photograph size Simon Loewen 17 Nov 17:30
  Urgently need to adjust photograph size Stefan Maerz 17 Nov 17:35
  Urgently need to adjust photograph size Jay Smith 17 Nov 17:35
  Urgently need to adjust photograph size Bob Meetin 17 Nov 17:36
   Urgently need to adjust photograph size Ruthy 17 Nov 18:26
    Urgently need to adjust photograph size Bob Meetin 17 Nov 19:16
  Urgently need to adjust photograph size Norman Silverstone 17 Nov 18:45
   Urgently need to adjust photograph size Ruthy 17 Nov 18:57
    Urgently need to adjust photograph size Stefan Maerz 17 Nov 19:14
     Urgently need to adjust photograph size Ruthy 17 Nov 19:31
      Urgently need to adjust photograph size Stefan Maerz 17 Nov 19:41
      Urgently need to adjust photograph size Ken Warner 17 Nov 19:43
    Urgently need to adjust photograph size John Meyer 17 Nov 19:24
     Urgently need to adjust photograph size Akkana Peck 18 Nov 00:27
    Urgently need to adjust photograph size Norman Silverstone 17 Nov 20:21
     Urgently need to adjust photograph size Ruthy 17 Nov 23:08
     Urgently need to adjust photograph size Dotan Cohen 18 Nov 08:37
2009-11-17 17:28:17 UTC (over 15 years ago)
Hello
I really need to adjust a photograph. It needs to be 600 by 600 pixels. When I change one value it seems to automatically adjust itself. I really need to get this done ASAP, so if you can help it would be graitely appreciated.
Simon Loewen
2009-11-17 17:30:18 UTC (over 15 years ago)
I think that you have to untick the box that forces one size e.g width) to change the second size (e.g height) to remain proportional. Then you ought to be able to set what ever sizes you like.
Ruthy wrote:
Hello
Stefan Maerz
2009-11-17 17:35:32 UTC (over 15 years ago)
Ok, Help is on the way!
1. Open up your picture in Gimp. 2. Then you will go to Image/Scale Image. Type in 600 and 600. Choose the Interpolation of either Cubic or Sinc, press Scale. And your done. Don't forget to save where ever you want your imgae. *However if your image is not at a 1:1 ratio it will look stretched one way or the other.
On Tue, Nov 17, 2009 at 10:28 AM, Ruthy wrote:
Hello
appreciated.
Ruthy (via www.gimpusers.com)
Jay Smith
2009-11-17 17:35:37 UTC (over 15 years ago)
If you really need to have 600 x 600 instead of 600 x "something less than 600", then you will need to set the smaller dimension to 600 and then CROP the image to fit the other dimension.
If it is not acceptable to lose part of the image by cropping, then if you change NON-relatively, you will distort (shrink/expand) one direction of the image. I do not think that is what you want either.
Jay
On 11/17/2009 11:28 AM, Ruthy wrote:
Hello
Bob Meetin
2009-11-17 17:36:43 UTC (over 15 years ago)
Ruthy wrote:
Hello
A little more detail might help, but generally if you have loaded it with the GIMP, then first change mode to RGB if not. Image --> Mode --> RGB
Now go to: Image --> Scale Image
and do the small dimension first (probably) and select Scale.
Then go to Image --> Canvas Size
unlink the chain and adjust the other dimension so that it is 4:3 proportion, center as necessary and click to Resize. If you resize an image it tends to get a little soft, so now go to:
Filters --> Enhance --> Sharpen --> about 50 --> and click OK
Then save as new name...
2009-11-17 18:26:21 UTC (over 15 years ago)
Ruthy wrote:
Hello
graitely
appreciated.
RGB
OK, i've got as far as this part:-
" adjust the other dimension so that it is 4:3 proportion"
but how do I do this please?
Norman Silverstone
2009-11-17 18:45:34 UTC (over 15 years ago)
Hello
I presume that you are using Scale Image. At the right hand side of the boxes where you enter the dimensions there are 2 chain links which are joined together, click on these and they will separate. Now you can enter your dimensions with out any problem.
Norman
2009-11-17 18:57:50 UTC (over 15 years ago)
Hello
graitely
appreciated.
Norman
Its a passport photograph, so doing the little chain things doesn't really work, as it becomes distorted.
Thats why I was trying to do what the previous poster suggested
Stefan Maerz
2009-11-17 19:14:00 UTC (over 15 years ago)
How large is your photo now(resolution)? Is is a scanned image, or did you take the photo on a digital camera? This info would help us tremendously. If your Image is not at a 1:1 ratio like a 600:600 image is, then you can 1, Distort the aspect ratio or 2, crop off the top/bottom, side(l or r), or some combination of the sides.
On Tue, Nov 17, 2009 at 11:57 AM, Ruthy wrote:
Hello
graitely
appreciated.
Norman
-- Ruthy (via www.gimpusers.com)
Bob Meetin
2009-11-17 19:16:51 UTC (over 15 years ago)
Ruthy wrote:
Ruthy wrote:
Hello
graitely
appreciated.
RGB
==>> here you would probably set the small dimension to 600 - then if you hit tab to another field the big dimension will adjust accordingly - when its right select scale. An SLR is commonly 3:2 proportion and a common digital may already be 4:3 proportion. ==>
When you hit Image --> Canvas Size you first break the chain. Then change the big dimension to "800". Move the cursor to the center function and drag the image around if necessary. Then click Resize.
Also to note - if the original image is larger than than the final when you do the enhance you should end up with a decent picture. If "much" smaller and you area actually growing it to 800x600 then you will lose quality noticably.
In the instructions I assumed that you are starting with a big pic.
If you resize an
John Meyer
2009-11-17 19:24:39 UTC (over 15 years ago)
Then you're probably going to want to crop out a square part of the picture and adjust that.
-----Original Message----- From: gimp-user-bounces@lists.XCF.Berkeley.EDU [mailto:gimp-user-bounces@lists.XCF.Berkeley.EDU] On Behalf Of Ruthy Sent: Tuesday, November 17, 2009 10:58 AM To: gimp-user@lists.XCF.Berkeley.EDU Subject: [Gimp-user] Urgently need to adjust photograph size
Hello
graitely
appreciated.
Norman
2009-11-17 19:31:19 UTC (over 15 years ago)
If
Hello
pixels.
graitely
appreciated.
Norman
really
the size now is 556W 796L.
Its a scanned image
Stefan Maerz
2009-11-17 19:41:14 UTC (over 15 years ago)
Ok great. That is critical.
I am going to have you scale it up.
1st You are going to use the scaling method with the chains connected and making sure to make the Width 600 Wide. 2nd. Use the Rectangle select tool(first button in the toolbox). Your width is now correct. However your Length will not be. So you will need to crop off some of the top and bottom. You can select first in the margins on the left move diagonally downward to the right. You can measue how far you have gone using the bottom left of your gimp window. There are two numbers there that you can use for reference. Then you should be done. An image of my description is here:
http://i337.photobucket.com/albums/n382/steferfootballdude13/example-1.jpg 3rd. Press Image/Crop to Selection.
I hope this solves your problem. Ideally you wold rescan the Image at 600wide or 600 hight and repete my steps. Email back if any questions!
If
Hello
pixels.
graitely
appreciated.
Norman
really
Its a scanned image
Ken Warner
2009-11-17 19:43:04 UTC (over 15 years ago)
You can't resize a 556x796 image to 600x600 without inducing distortion.
That should be obvious. Resize the image to 600xXXX using the scale image control panel with the width and height chained together. Then crop a 600 x 600 portion of the image.
If
Hello
pixels.
graitely
appreciated.
Norman
really
Its a scanned image
Norman Silverstone
2009-11-17 20:21:02 UTC (over 15 years ago)
< snip>
There is a plug-in called Liquid Rescale which would probably do exactly what you want.
Norman
2009-11-17 23:08:26 UTC (over 15 years ago)
< snip>
really
Norman
hay everyone,
I just got back from a photographer friends. She struggled to do much with the photograph so we just took a new one. So its all fine now.
But I really want to thank you all for your help and for getting back to me so quickly, thank you.
Well its late now and I've had enough of messing about with the computer for today.
Good night, and thank you againe
Akkana Peck
2009-11-18 00:27:53 UTC (over 15 years ago)
John Meyer writes:
Agreed -- Crop is what you want.
...Akkana
Dotan Cohen
2009-11-18 08:37:26 UTC (over 15 years ago)
Depending to which nation he is applying for his passport, altering the photograph in that way may be illegal. The two nations for which I hold passports allow only cropping and resizing of the image, even colour adjustment and free rotation is forbidden.
