Layer selection using mouse click
Layer selection using mouse click Peter Rosenberg 15 Nov 21:52
  Layer selection using mouse click Nathan Lane 16 Nov 18:51
  Layer selection using mouse click Joao S. O. Bueno 16 Nov 19:06
  Layer selection using mouse click GSR - FR 16 Nov 19:12
   Layer selection using mouse click Peter Rosenberg 16 Nov 19:37
Peter Rosenberg
2009-11-15 21:52:06 UTC (over 15 years ago)
How can I change the layer selection by clicking on the object in the image?
Nathan Lane
2009-11-16 18:51:58 UTC (over 15 years ago)
I don't believe that you can. For one, generally speaking, GIMP is a raster-based image program and thus does not have the notion of objects. If you don't want to keep going back and forth between the Layers dialog and your image, then another option is to right-click on the image, go to Layer and pick an option. Most of those options also have shortcuts on the keyboard, so you could also utilize those.
Nathan
Joao S. O. Bueno
2009-11-16 19:06:52 UTC (over 15 years ago)
In preferences->Tool options, configure the "move tool" to "set the layer or path as active".
Sorry -- it is not my fault this is hidden - I'd rather keep this at the tool options dialog for the move tool.
js ->
GSR - FR
2009-11-16 19:12:52 UTC (over 15 years ago)
p.rosenberg@gmx.net (2009-11-15 at 2152.06 +0100):
Move tool has a pick layer or guide mode, it will select the topmost layer that is non transparent for the pixel you click.
GSR
Peter Rosenberg
2009-11-16 19:37:56 UTC (over 15 years ago)
Thank you, that is the solution! :-)
