Gimp 2.6 -vista possible crash and fix
Gimp 2.6 -vista possible crash and fix photocomix 08 Nov 22:18
Gimp 2.6 -vista possible crash and fix Jernej Simon?i? 09 Nov 20:50
2009-11-08 22:18:28 UTC (over 15 years ago)
Somebody reported that after updating Vista to SP2 gimp abort when loading
Fix "if you right click on your shortcut to GIMP and go to the compatibility and then check Run this program in compatibility mode for: Then just about anything should work"
i report here because the cause of the crash was very hard to find
http://www.gimptalk.com/forum/help%C7%83-gimp-won%CA%B9t-load-filters%C7%83-t45201s25.html
and is possible that other Vista users will get a similar problem after updating the SP
Jernej Simon?i?
2009-11-09 20:50:57 UTC (over 15 years ago)
This should never be necessary, and future versions of GIMP will have manifest which will override these settings. I am unable to reproduce the original problem on a fully patched 32bit Vista SP2.
