Help needed with text
8 of 8 messages available
Help needed with text Flyfishing48 04 Oct 14:38
  Help needed with text Daniel Hornung 04 Oct 14:55
   Help needed with text Flyfishing48 04 Oct 19:19
    Help needed with text Flyfishing48 04 Oct 19:36
    Help needed with text Daniel Hornung 04 Oct 20:46
  Help needed with text Dmitry Trunikov 05 Oct 09:00
   Help needed with text Flyfishing48 07 Oct 01:50
    Help needed with text Dmitry Trunikov 07 Oct 08:18
2009-10-04 14:38:10 UTC (over 15 years ago)
I am just starting to use GIMP. I am having trouble getting the effect I want.
I have 2 photos one over the other. I want to put text over the upper layer and have the lower layer show through. If I put a mask over the upper layer and draw on it with black it does just what I want. Problem is I want to use text not draw on it. Every way I try to add text I get a new layer, I seem to get text on the mask for the upper layer.
thanks in advance for any help with this.
Daniel Hornung
2009-10-04 14:55:54 UTC (over 15 years ago)
Short hint: Text to selection, change to mask, fill with black(or white, whatever you want)
2009-10-04 19:19:29 UTC (over 15 years ago)
just
Daniel,
Thank you for replying.
I must not be getting your hint. I add my two layers, add a mask (regular) to the top layer.
Bring up text and add it.
Then I select add text to selection
then I select the mack and fill with black. I tried FG and BG. No luck.
What am I doing wrong?
2009-10-04 19:36:22 UTC (over 15 years ago)
I
want.
just
Daniel,
Daniel,
I should add that I did get the opposite of what I wanted to work. All of the top layer went transparent and the text stayed. I want the text to go transparent, so the parts of the underlying picture shows through the text.
Daniel Hornung
2009-10-04 20:46:50 UTC (over 15 years ago)
then I select the mask and fill with black. I tried FG and BG.
If the mask is white before, that layer should've been completely opaque, so filling the selection with black (simply drag&drop from the color patch onto the image) should make the layer below shine through.
Of course, if the upper layer doesn't have a mask yet, simply choosing "from selection (inverted)" when creating the mask would've been the most straightforward way.
Cheers, Daniel
Dmitry Trunikov
2009-10-05 09:00:09 UTC (over 15 years ago)
Text to selection, select top layer with photo (make sure he can be transparent), press button "Del".
2009-10-07 01:50:34 UTC (over 15 years ago)
layer
just
mask
Dmitry,
Thank you for the reply, but I have had no success with this problem as yet. In your reply...(make sure he can be transparent), how do I do that?
Thanks Tom
Dmitry Trunikov
2009-10-07 08:18:54 UTC (over 15 years ago)
Tom C. wrote:
[cut]
Dmitry,
A layer can be transparent or not. The transparency is defined by presence of alpha channel in it.
Usually when you add a new layer you are able to specify which is background (FG, BG or Transparent).
When you add layer from JPG file it has no alpha channel, so you should add it manually.
To add alpha channel you should select the layer, right-click on it to open context menu and then click on "Add alpha-channel" (or something like that, I don't know how it is in english as I use gimp with russian localization).
Hope this will help you.
Dmitry
