Bits per channel
7 of 8 messages available
Bits per channel Phil Labonte 29 Sep 03:36
  Bits per channel Martin Nordholts 29 Sep 07:10
   Bits per channel Ken Warner 29 Sep 13:43
    Bits per channel David Gowers 29 Sep 15:03
  Bits per channel phanisvara das 29 Sep 08:18
   Bits per channel Joerg Bergmann 29 Sep 09:44
1254209740.21783.7.camel@pt... 07 Oct 20:20
  Bits per channel phanisvara das 29 Sep 09:58
Phil Labonte
2009-09-29 03:36:52 UTC (about 16 years ago)
Bits per channel
I have looked online on the Gimp site and I am not clear if Gimp supports 16 or 24 or 32 bit images?
Can someone point me to the correct answer for Gimp 2.6.7
Thanks
Martin Nordholts
2009-09-29 07:10:17 UTC (about 16 years ago)
Bits per channel
Hi
GIMP 2.6 does not and GIMP 2.8 will not work with higher than 8 bits-per-channel images. GIMP 2.10/3.0 will.
BR, Martin
phanisvara das
2009-09-29 08:18:07 UTC (about 16 years ago)
Bits per channel
as far as i know, GIMP processes colors with 16 bit precision when "use GEGL" is enabled from the "colors" menu. work is in progress to make it possible to fully support opening & saving of 16 bit (or higher?) images.
Joerg Bergmann
2009-09-29 09:44:16 UTC (about 16 years ago)
Bits per channel
Am Dienstag, den 29.09.2009, 11:48 +0530 schrieb phanisvara das:
Wrong. GEGL uses 32 bit floating point numbers, that gives 128 bit per coloured pixel (with alpha channel). Using 16 bit integers, the maximum intensity of a color channel is 0xffff. This may lead to temporarily color cropping during multi-step operations, even if the final channel intensity is below 0xffff. By using floating point numbers, no temorarily cropping will occur.
Joerg
phanisvara das
2009-09-29 09:58:03 UTC (about 16 years ago)
Bits per channel
thank you for clarifying that. i've read about it a while ago and didn't remember correctly.
NB: this reply arrived at my personal email address. that doesn't bother me, but other list users won't see it; seems your email client defaults to the wrong adress...
phani.
Ken Warner
2009-09-29 13:43:37 UTC (about 16 years ago)
Bits per channel
Working with 16 bit per channel images will be great!
16 bits per channel is essential when working with high dynamic range (HDR) images.
What is the timeline for 2.10/3.0?
Hi
BR, Martin
David Gowers
2009-09-29 15:03:04 UTC (about 16 years ago)
Bits per channel
I believe you'll find that you can only get a meaningful timeline for eg. 2.10 after 2.8 is released.
Looking ahead further than 'the release we are currently working towards' is unreliable, especially since all development on GIMP is done by unpaid volunteers.
