cutting objects out of gif
cutting objects out of gif ScottDB 13 Sep 23:37
  cutting objects out of gif bhaaluu 13 Sep 23:43
   cutting objects out of gif jolie 14 Sep 06:28
    cutting objects out of gif photocomix 14 Sep 14:48
2009-09-13 23:37:41 UTC (over 15 years ago)
I would like to know if it is possible to take an ordinary gif pic like a cartoon and cut the cartoon figure out of it? Then I could place it on a transparent layer. If so can someone tell me how?
Thanks, Scott
bhaaluu
2009-09-13 23:43:15 UTC (over 15 years ago)
Toggle Quick Mask Shift + Q
It is in the lower left hand corner of the image window (Linux + Gimp 2.6).
Thanks, Scott
Scott (via www.gimpusers.com)
2009-09-14 06:28:16 UTC (over 15 years ago)
Hi Scott,
You need to make a selection of the cartoon figure. Check the gimp manual on how to do this, there are too many ways to explain all here. Then go to select float.
Then create a new layer.
Make the background layer invisible or delete the background layer if you no longer need it.
link to the manual http://docs.gimp.org/2.6/en/
Hope this helps.
Thanks, Scott
2009-09-14 14:48:13 UTC (over 15 years ago)
If the gif is animated maybe be hard if what you want to cut is moving
Basically you will have to cut in each layer as far i know no way to automatize
And first will be better change image mode in RGB so you may feather your cut
