Scaling and resolution
7 of 8 messages available
Scaling and resolution oar 11 Sep 16:57
  Scaling and resolution David Gowers 13 Sep 00:16
   Scaling and resolution Jaime Seuma 14 Sep 11:12
    Scaling and resolution Bob Long 14 Sep 11:56
     Scaling and resolution 127markaz 14 Sep 15:02
    4AAEDB90.8030300@yahoo.com Patrick Horgan 15 Sep 02:10
     Scaling and resolution David Gowers 15 Sep 02:59
      Scaling and resolution Jaime Seuma 15 Sep 10:58
2009-09-11 16:57:16 UTC (about 16 years ago)
Hello all,
I experimented with the resolution settings in the gimp --> scale image menu.
The resolution does not seem to have any effect on the rendering of the image on a computer screen.
It has no effect on file size either.
I checked this by scaling and saving the same image in 3 different resolutions
(but no other changes):
72dpi, 300dpi, 600dpi.
When opening them again all were rendered at the same size on the screen.
I concluded that the dpi setting is only used by printers. Is this correct?
David Gowers
2009-09-13 00:16:53 UTC (about 16 years ago)
On Sat, Sep 12, 2009 at 12:27 AM, Michael J. M. wrote:
Hello all,
No, if you turn off View->Dot for dot then the DPI relative to your display DPI is used to scale your view of the image.
Jaime Seuma
2009-09-14 11:12:10 UTC (about 16 years ago)
Hi
This is an interesting question also to me.
That much I had already found; but still, when I open a file that has been scaled only in resolution (for instance 300->700), still the different imageviewers display the same image.
I know that this is not a Gimp related question, and I feel that the Gimp's approach is correct; but still I don't understand the whole resolution thing completely. I take it many imageviewers simply don't have the capability of taking the resolution into consideration, when rendering an image. I'm I right?
Regards
Jaime
Bob Long
2009-09-14 11:56:23 UTC (about 16 years ago)
Jaime Seuma wrote:
Hi
See if this helps:
http://www.scantips.com/basics01.html
2009-09-14 15:02:18 UTC (about 16 years ago)
Jaime Seuma wrote:
See if this helps:
Thank you for making this link available.
David Gowers
2009-09-15 02:59:58 UTC (about 16 years ago)
On Tue, Sep 15, 2009 at 9:40 AM, Patrick Horgan wrote:
Jaime Seuma wrote:
Hi
A 400 pixel wide image will always have exactly 400 pixels across, so on any given display device it will show the same irregardless of the resolution. On a 70dpi device it will be 5.71 inches wide, on a 90dpi device it will be 4.44 inches wide, on a 300dpi device it will be 1 1/3 in.
If you set the dpi for the image to match the device you intend to show it on, then if, for example you change units on the bottom of the drawing window to inches, it will accurately report to you the sizes of things as you expect to display them.
It won't make it display any differently though.
In GIMP (and Photoshop, and some other editing software) it will make it display differently. If your display reports its size correctly and Dot for Dot is off, the image will display at the correct size, closely matching the original DPI (of course you do not get any more actual dots out of this -- it just means that the relative scale of things is correct).
It's easy to see this if you halve the DPI for one dimension (eg. so DPI == 36x72) and then turn off Dot for Dot
On a 300dpi device it will
still display as 1 1/3 in, even if you set the resolution to 70dpi.
This is true for most simple 'viewing' software, which doesn't scale the view to be accurate. Not for editors that try to be accurate, such as GIMP.
David
Jaime Seuma
2009-09-15 10:58:47 UTC (about 16 years ago)
Thank you all for the tips and links, I think this is enough info to make me understand the whole thing, and to make me feel comfortable with it.
Best regards
Jaime
David
