Problems with image pasted into layer
Problems with image pasted into layer LOEWENTHAL Simon 09 Aug 12:31
  Problems with image pasted into layer saulgoode@flashingtwelve.brickfilms.com 09 Aug 17:19
   Problems with image pasted into layer bgw 09 Aug 20:28
LOEWENTHAL Simon
2009-08-09 12:31:29 UTC (almost 16 years ago)
Dear all,
Is there a tutorial that could tell me how to sort out this problem.
1) Created a new transparent layer 2) Pasted image into layer.
3) Noticed that I could not do anything else with Gimp so do a New - Layer, and it created something called a Pasted Layer. 4) Used select tool to select the pasted image and it correctly highlighted the whole image.
5) Used the Move Tool to move the highlighted image, but instead of only moving the highlighted image Gimp moved the 'whole' background and the image as it it were one item!
How can I uncouple these two things, which I presume conprise of i) the image and ii) the background colour.
I am a bit confused because although Gimp can clearly identify and select/highlight the pasted image, when it comes to moving the image it cannot differentiate between the pasted image and the background. So, what has linked these two together?
Rdgs, S.
2009-08-09 17:19:22 UTC (almost 16 years ago)
You need to hold down the SHIFT key while dragging your layer with the Move Tool, otherwise GIMP will move the topmost layer which contains a non-transparent pixel under the pointer (since your added layer was transparent, the layer underneath it gets checked).
This behavior is controlled by the "Tool Toggle" setting in the Move Tool's Options dialog. You can change the option to move the active layer by default, obviating the need to hold down SHIFT.
Quoting LOEWENTHAL Simon :
Dear all,
bgw
2009-08-09 20:28:03 UTC (almost 16 years ago)
It's useful to note that, when you have selected the move tool and click on the mouse button, the layer that will move (since where you are clicking happens to be transparent in the layer you are trying to move) is highlighted in the Layers dock, and when you release the mouse button the currently selected layer will again be highlighted.
Quoting LOEWENTHAL Simon:
Dear all,
