GTK make problem
8 of 8 messages available
GTK make problem julien 01 Aug 20:39
  GTK make problem Martin Nordholts 01 Aug 20:45
   GTK make problem julien 04 Aug 15:57
    GTK make problem Doug 05 Aug 11:54
     GTK make problem Martin Nordholts 05 Aug 18:55
     GTK make problem julien 06 Aug 07:50
      GTK make problem Martin Nordholts 06 Aug 08:23
       GTK make problem Doug 06 Aug 11:57
julien
2009-08-01 20:39:02 UTC (over 16 years ago)
GTK make problem
I am trying to install gtk+-2.16.5 from sources under openSuse-11.0, (before installing unstable GIMP for UI translation). "Configure" gives no error message.
Running "make" gives this error:
make[3]: going into directory « /home/.../telechar/gtk+-2.16.5/gtk » /bin/sh ../libtool --mode=link gcc -DGDK_PIXBUF_DISABLE_DEPRECATED -g -O2 -Wall -o gtk-query-immodules-2.0 queryimmodules.o libgtk-x11-2.0.la ../gdk-pixbuf/libgdk_pixbuf-2.0.la ../gdk/libgdk-x11-2.0.la libtool: link: gcc -DGDK_PIXBUF_DISABLE_DEPRECATED -g -O2 -Wall -o .libs/gtk-query-immodules-2.0 queryimmodules.o ./.libs/libgtk-x11-2.0.so -L/usr/local/lib
/home/.../telechar/gtk+-2.16.5/gdk/.libs/libgdk-x11-2.0.so /usr/lib/libatk-1.0.so /usr/lib/libgobject-2.0.so /usr/lib/libgmodule-2.0.so /usr/lib/libglib-2.0.so -lpcre -lpangoft2-1.0 ../gdk-pixbuf/.libs/libgdk_pixbuf-2.0.so ../gdk/.libs/libgdk-x11-2.0.so -lpangocairo-1.0 -lpango-1.0 /usr/lib/libXinerama.so /usr/lib/libXcursor.so /usr/lib/libXcomposite.so /usr/lib/libXext.so /usr/lib/libXdamage.so /usr/lib/libXfixes.so /usr/lib/libcairo.so /usr/lib/libfontconfig.so /usr/lib/libfreetype.so -lexpat /usr/lib/libglitz.so /usr/lib/libpng12.so -lz /usr/lib/libxcb-render-util.so /usr/lib/libxcb-render.so /usr/lib/libXrender.so /usr/lib/libpixman-1.so /usr/lib/libX11.so /usr/lib/libxcb-xlib.so /usr/lib/libxcb.so -lXau /home/.../telechar/gtk+-2.16.5/gdk-pixbuf/.libs/libgdk_pixbuf-2.0.so /usr/local/lib/libgio-2.0.so /usr/local/lib/libgobject-2.0.so /usr/local/lib/libgmodule-2.0.so -ldl /usr/local/lib/libglib-2.0.so -lm ./.libs/libgtk-x11-2.0.so: undefined reference to `g_signal_chain_from_overridden_handler' /usr/local/lib/libgio-2.0.so: undefined reference to `g_poll' ./.libs/libgtk-x11-2.0.so: undefined reference to `g_signal_override_class_handler'
./.libs/libgtk-x11-2.0.so: undefined reference to `g_dpgettext2' ./.libs/libgtk-x11-2.0.so: undefined reference to `g_set_error_literal' ./.libs/libgtk-x11-2.0.so: undefined reference to `g_signal_new_class_handler'
./.libs/libgtk-x11-2.0.so: undefined reference to `g_dgettext' collect2: ld returned 1 exit status
make[3]: *** [gtk-query-immodules-2.0] Error 1
I can't find how to resolve this problem. I'd be grateful for any help.
Martin Nordholts
2009-08-01 20:45:59 UTC (over 16 years ago)
GTK make problem
Looks like you're not linking against the proper GLib library, make sure to setup PKG_CONFIG_PATH and LD_LIBRARY_PATH at configure time so that the right dependencies are found preferably through the use of config.site.
/ Martin
julien
2009-08-04 15:57:42 UTC (over 16 years ago)
GTK make problem
I had installed glib-2.20.4 through a rpm built with checkinstall. I uninstalled it and re-installed glib with "make install".
I have the glib-2.0 directory in /usr/share, /usr/local/share, /usr/local/lib
The PKG-CONFIG_PATH and LD_LIBRARY_PATH environment variables are empty.
I tried "export LD_LIBRARY_PATH='/usr/local/lib' && export PKG_CONFIG_PATH='/usr/local/lib' " before ./configure in the gtk+-2.16.5 directory : my problem persits.
I also added the three glib-2.0 paths in ld.so.conf, without any success.
Is this actually a glib path problem? I have the /usr/local/lib/libgio-2.0.so file...
/ Martin
Doug
2009-08-05 11:54:42 UTC (over 16 years ago)
GTK make problem
PKG_CONFIG_PATH needs to point to a pkconfig folder containing various .pc files.
Look in /usr/lib/pkconfig and /usr/local/lib/pkconfig and check where various glib- and gtk-related .pc files are located. You may well need both pkconfig folders. Then
PKG_CONFIG_PATH=/usr/local/lib/pkconfig:/usr/lib/pkconfig; export PKG_CONFIG_PATH; ./configure
You should be able to compile but you may not be able to run, because the program can't find this or that library which you know you have - you get a message saying "couldn't find library lib......so....."
Setting LD_LIBRARY_PATH may avoid that happening, but quite often it doesn't.
Usually it's because the program insists on looking for that library in /usr/lib when you've got it in /usr/ local (or /usr/lib64 on a 64-bit machine).
In that case, as root create absolute links from /usr/lib to all those particular library lib......so... files in /usr/local/lib (or wherever). It solves most problems.
HTH
Doug
/ Martin
Martin Nordholts
2009-08-05 18:55:07 UTC (over 16 years ago)
GTK make problem
Setting LD_LIBRARY_PATH is only necessary at configure time. After that it is not necessary since libtool sets the necessary rpaths of the binaries it builds, at least for the babl/GLib/GTK+/GEGL/GIMP stack.
And why use a prefix that requires root write privileges?
Instead of manually setting PKG_CONFIG_PATH and LD_LIBRARY_PATH, let configure do that. Just put this in /home/user/dev/share/config.site:
export PKG_CONFIG_PATH="/home/user/dev/lib/pkgconfig:$PKG_CONFIG_PATH" export LD_LIBRARY_PATH="/home/user/dev/lib:$LD_LIBRARY_PATH"
and invoke ./autogen.sh or configure with --prefix=/home/user/dev. By having config.site there is no need to keep PKG_CONFIG_PATH and LD_LIBRARY_PATH globally, and automatic reconfiguration when making after e.g. configure.in/ac changes works without issues.
/ Martin
julien
2009-08-06 07:50:27 UTC (over 16 years ago)
GTK make problem
glib and gtk-related .pc files are in /usr/lib/pkgconfig. In /usr/local/lib/pkgconfig I have babl.pc, gegl.pc, gio-2.0.pc, gio-unix-2.0.pc, glib-2.0.pc but no gtk.pc, probably because it is not installed yet?
I ran
PKG_CONFIG_PATH=/usr/local/lib/pkgconfig:/usr/lib/pkgconfig export PKG_CONFIG_PATH
and still I have this damned eroor on 'make':
libtool: link: gcc -DGDK_PIXBUF_DISABLE_DEPRECATED -g -O2 -Wall -o .libs/gtk-query-immodules-2.0 queryimmodules.o ./.libs/libgtk-x11-2.0.so -L/usr/local/lib /home/julien/telechar/gtk+-2.16.5/gdk/.libs/libgdk-x11-2.0.so /usr/lib/libatk-1.0.so /usr/lib/libgobject-2.0.so /usr/lib/libgmodule-2.0.so /usr/lib/libglib-2.0.so -lpcre -lpangoft2-1.0 ../gdk-pixbuf/.libs/libgdk_pixbuf-2.0.so ../gdk/.libs/libgdk-x11-2.0.so -lpangocairo-1.0 -lpango-1.0 /usr/lib/libXinerama.so /usr/lib/libXcursor.so /usr/lib/libXcomposite.so /usr/lib/libXext.so /usr/lib/libXdamage.so /usr/lib/libXfixes.so /usr/lib/libcairo.so /usr/lib/libfontconfig.so /usr/lib/libfreetype.so -lexpat /usr/lib/libglitz.so /usr/lib/libpng12.so -lz /usr/lib/libxcb-render-util.so /usr/lib/libxcb-render.so /usr/lib/libXrender.so /usr/lib/libpixman-1.so /usr/lib/libX11.so /usr/lib/libxcb-xlib.so /usr/lib/libxcb.so -lXau /home/.../telechar/gtk+-2.16.5/gdk-pixbuf/.libs/libgdk_pixbuf-2.0.so /usr/local/lib/libgio-2.0.so /usr/local/lib/libgobject-2.0.so /usr/local/lib/libgmodule-2.0.so -ldl /usr/local/lib/libglib-2.0.so -lm ./.libs/libgtk-x11-2.0.so: undefined reference to `g_signal_chain_from_overridden_handler' /usr/local/lib/libgio-2.0.so: undefined reference to `g_poll' ./.libs/libgtk-x11-2.0.so: undefined reference to `g_signal_override_class_handler'
make[4]: *** [gtk-query-immodules-2.0] Error 1
The problem doesn't seem to be in pkgconfig or glib. What are these "undefined reference"?
HTH
Doug
/ Martin
Martin Nordholts
2009-08-06 08:23:04 UTC (over 16 years ago)
GTK make problem
I ran
PKG_CONFIG_PATH is a configure time environment variable. make does not care about PKG_CONFIG_PATH. You need to reconfigure with PKG_CONFIG_PATH and probabl LD_LIBRARY_PATH set (but again, note that LD_LIBRARY_PATH is not needed when later running the built software due to libtool's use of rpaths.
/ Martin
Doug
2009-08-06 11:57:28 UTC (over 16 years ago)
GTK make problem
I ran
/ Martin
As Martin says
./configure
Then 'make'.
If 'make' still complains it may mean you've got the 'stripped' version of one or more packages and have to download the development versions (they usually have "-devel" in their names) which have header files needed for compilation.
A similar problem came up about a month ago on the mailing list - it might also be worth your while having a look in the Gimp-user archives (July 2009; subject babl; author John Culleton, Doug, etc)
Doug
