Compile problems and GTK
13 of 14 messages available
Compile problems and GTK Brad Kligerman 15 Jan 15:40
  Compile problems and GTK Neil Watson 15 Jan 15:50
  Compile problems and GTK Sven Neumann 15 Jan 18:03
   Compile problems and GTK Brad Kligerman 15 Jan 18:49
    Compile problems and GTK Sven Neumann 15 Jan 20:02
  Compile problems and GTK Brad Kligerman 20 Jan 23:19
   Compile problems and GTK Sven Neumann 21 Jan 01:00
Compile problems and GTK misfit-x 15 Jan 21:26
  Compile problems and GTK Sven Neumann 15 Jan 22:09
400875FA.7010604@club-inter... 07 Oct 20:16
  Compile problems and GTK misfit-x 17 Jan 06:18
   Compile problems and GTK Sven Neumann 17 Jan 11:52
    Compile problems and GTK Brad Kligerman 17 Jan 12:48
   Compile problems and GTK Brad Kligerman 17 Jan 12:08
Brad Kligerman
2004-01-15 15:40:47 UTC (over 21 years ago)
Hi all/
I've been trying to upgrade from GIMP 1.2.3 that was installed with RH9 to GIMP 1.3.23.
It won't configure, and I get the following...
[root@localhost gimp-1.3.23]# ./configure ......>>>>>
checking for pkg-config... (cached) /usr/bin/pkg-config checking for GTK+ - version >= 2.2.2... *** 'pkg-config --modversion gtk+-2.0' returned 2.2.4, but GTK+ (2.2.1) *** was found! If pkg-config was correct, then it is best *** to remove the old version of GTK+. You may also be able to fix the error
*** by modifying your LD_LIBRARY_PATH enviroment variable, or by editing *** /etc/ld.so.conf. Make sure you have run ldconfig if that is *** required on your system.
*** If pkg-config was wrong, set the environment variable PKG_CONFIG_PATH *** to point to the correct configuration files no configure: error: Test for GTK+ failed. See the file 'INSTALL' for help.
I installed GTK 2.2.4 and followed all the other installation instructions. When I check the version of GTK+ with Synaptic, it shows _GTK2 - version 2.2.1-4_ and not 2.2.4. Is this where the problem is coming from. Any ideas??
Thanks.
/brad.
Neil Watson
2004-01-15 15:50:59 UTC (over 21 years ago)
On Thu, Jan 15, 2004 at 03:40:47PM +0100, Brad Kligerman wrote:
Hi all/
Perhaps you have the old version of GTK+ residing at /usr/bin and the new version somewhere in /usr/local?
2004-01-15 18:03:29 UTC (over 21 years ago)
Brad Kligerman writes:
Yes, that's where your problem is coming from. While pkg-config locates the new version, your linker takes the library from /usr/lib. The error message suggests the possible solutions. You can modify the linker behaviour by adjusting your LD_LIBRARY_PATH enviroment variable or by editing /etc/ld.so.conf.
Brad Kligerman
2004-01-15 18:49:05 UTC (over 21 years ago)
I already had edited _/etc/ld.so.conf_ and ran _ldconfig_ as suggested in the message. It also suggests that I remove version GTK+ 2.2.1, which I never installed, and to the best of my knowlege, is not on my system. Synaptics says that I have _GTK2 - version 2.2.1-4_ and not _GTK+2.2.4_. Could this be the problem??
2004-01-15 20:02:41 UTC (over 21 years ago)
So where did you put /usr/local/lib in your library search path then? Does it appear before the path holding the older version of the library?
misfit-x
2004-01-15 21:26:59 UTC (over 21 years ago)
On Thu, 2004-01-15 at 09:40, Brad Kligerman wrote:
Hi all/
I solved this one myself. Just get GTK+2.2.4 SOURCES (not the rpm or anything), and compile with these flags. Here's how I did it:
1. remove the old version of gtk (rpm -e --force --nodeps gtk+-2.2.1 for example or whatever will remove just that. Don't remove any other gtk+ packages!!)
2. mkdir /opt/lib/gtk+-2.2.4
3. Compile and install the new gtk+-2.2.4 sources using: # ./configure --eprefix=/opt/lib/gtk+-2.2.4 --prefix=/opt/lib/gtk+-2.2.4 # make
# su
(type in your root password)
# make install
4. Next (still as root), edit /etc/ld.so.conf in a text editor and add the following line:
/opt/lib/gtk+-2.2.4/lib
5. Still as root:
# /sbin/ldconfig
NOTE: If you compile other apps that use GTK+ you might get an error about PKG_CONFIG_PATH not pointing to gtk+-2.0.pc. Do the following to fix that:
# locate gtk+-2.0.pc (take note of the path here) # export PKG_CONFIG_PATH=(path noted above w/o the *.pc filename included)
I know Gimp wants freetype libraries newer than what RH9 has but I didn't install them because it messes with XWindows on my system - the font path in the config gets blitzed. :( Gimp 1.3.23 and Gimp 2.0pre1 both work ok anyway without further packages added other than compiling/installing GTK+2.2.4. If you do like above, it should work ok. Don't know about tablet though because I don't have an art tablet or anything, just mouse.
.:: misfit-x ::.
2004-01-15 22:09:35 UTC (over 21 years ago)
misfit-x writes:
If tablet support is desired, gtk+ needs to be configured to provide it. To do so, pass the option --with-xinput=xfree to the gtk+ configure script.
misfit-x
2004-01-17 06:18:37 UTC (over 21 years ago)
When I tried to uninstall GTK+ (2.2.1) as you suggested, it said 2.2.1 was not installed.
# rpm -qa | grep gtk+
If it shows 2.2.1 then:
# rpm -e --force gtk+-2.2.1
If that didn't work, then there's a config somewhere that's still saying there's a GTK+-2.2.1 somewhere. I have another idea... REinstall GTK+2.2.1, then uninstall it. Then reinstall (just make install in the source tree you compiled GTK+-2.2.4 in, if you still have the sources compiled (ie. didn't delete the dirs or run make clean yet)). And see if that helps.
Before I throw in the towel and go back to Photoshop, I just want to understand what my _/etc/ld.so.conf_ should look like. Mine has the following...
/opt/lib/gtk+-2.2.4/lib/pkgconfig
I would think it should be in /opt/lib/gtk+-2.2.4/lib instead?
/usr/X11R6/lib
/usr/kerberos/lib
/usr/lib/qt-3.1/lib
/usr/lib/sane
Rest of this looks good to me.
If you really really want to run PhotoShop, you can in linux using WINE (www.winehq.org). Runs slower but works - at least PS LE 5 worked for me. However, I would rather use Gimp, personally.
You can still use Gimp 1.2.x but the new 2.0pre1 is really nice. :)
2004-01-17 11:52:35 UTC (over 21 years ago)
misfit-x writes:
It isn't even necessary to remove the 2.2.1 version. The problem here is the wrong usage of /etc/ld.so.conf as you outlined below:
Just like misfit-x pointed out already, this is of course completely wrong. /etc/ld.so.conf has nothing to do with pkg-config. I would strongly suggest to take a short look at the man-pages before doing such changes. It certainly helps to know what files you are editing.
This is a very unusual install prefix that was choosen for gtk+ here. But if it's indeed "/opt/lib/gtk+-2.2.4", then the value you suggested is absolutely correct.
Brad Kligerman
2004-01-17 12:08:33 UTC (over 21 years ago)
misfit-x/
Thanks for pursuing this with me.
The results:
[root@localhost gimp-1.3.23]# rpm -qa | grep gtk+ gtk+-devel-1.2.10-25
gtk+-1.2.10-25
But when I changed it from _gtk+_ to _rpm -qa | grep gtk2_ I got the following :
[root@localhost gimp-1.3.23]# rpm -qa | grep gtk2 pygtk2-devel-1.99.14-4
pygtk2-1.99.14-4
gtk2-2.2.1-4
gtk2-devel-2.2.1-4
pygtk2-libglade-1.99.14-4
gtk2-engines-2.2.0-2
Notice how _GTK+ 2.2.4_ becomes _gtk2-2.2.1-4_. Could this be where my system is getting gtk 2.2.1??
/brad
/usr/X11R6/lib
/usr/kerberos/lib
/usr/lib/qt-3.1/lib
/usr/lib/sane
Brad Kligerman
2004-01-17 12:48:53 UTC (over 21 years ago)
Sven/
Point well taken. In my desperation to get this thing installed, I got misfit-x's indications mixed up. I guess I will take a look at the man-pages, but I still can't figure out why I can't straighten this thing out, especially since I already have an older GIMP that works on my system.
/brad.
Brad Kligerman
2004-01-20 23:19:55 UTC (about 21 years ago)
Sven+x/
By hook or by crook, I finally managed to compile GIMP2.0. I still don't understand why it was such a mess, but I learned a whole bunch in the process. Thanks go out to both of you for your patience.
As for GIMP 2.0, I started it immediately after I got it compiled and everything worked fine, in fact it looks great. But since I rebooted, I get the following message:>
$ gimp-1.3
gimp-1.3: error while loading shared libraries: libgimpcolor-1.3.so.24: cannot open shared object file: No such file or directory
The file _libgimpcolor-1.3.so.24_ is in /usr/local/lib and is linked to _libgimpcolor-1.3.so.24.1.0_.
Any ideas what's going on?
Thanks again, /brad.
Hi all/
[root@localhost gimp-1.3.23]# ./configure .......>>>>>
Thanks.
/brad.
2004-01-21 01:00:59 UTC (about 21 years ago)
$ gimp-1.3
You probably set LD_LIBRARY_PATH to get gimp going and your linker can't find the library now that it isn't set. You will want to read the ldconfig man-page to learn how to configure the linker path persistently.
