sharpening
12 of 12 messages available
sharpening Norman Silverstone 27 Jul 19:47
  sharpening Bob Meetin 27 Jul 19:53
   sharpening Norman Silverstone 27 Jul 20:48
  sharpening danny tauro 27 Jul 21:12
  sharpening peter kostov 27 Jul 21:36
  sharpening Martin Cracauer 27 Jul 22:10
  sharpening phanisvara das 28 Jul 07:15
   sharpening Norman Silverstone 28 Jul 08:37
    sharpening Carusoswi 05 Sep 09:24
     sharpening Norman Silverstone 05 Sep 10:01
     sharpening David Gowers 05 Sep 10:02
     sharpening phanisvara das 05 Sep 10:05
Norman Silverstone
2009-07-27 19:47:22 UTC (almost 16 years ago)
sharpening
Quite some time ago a method for sharpening was given here and which I have enjoyed using. Unfortunately, I have lost my notes and I would be grateful if the method could be posted again, please.
Norman
Bob Meetin
2009-07-27 19:53:46 UTC (almost 16 years ago)
sharpening
Filters --> Enhance --> Sharpen
Things break up after around 70% Any time I resize any image I need to resharpen it.
If enhance/sharpen is grayed out make sure the image is RGB
Image --> Mode --> RGB
Norman
Norman Silverstone
2009-07-27 20:48:10 UTC (almost 16 years ago)
sharpening
Thanks Bob, but what I looking for is not part of the Gimp menu.
Norman
danny tauro
2009-07-27 21:12:11 UTC (almost 16 years ago)
sharpening
In flickr in the gimp user group there are several sharpening procedure outlined. search there....Great group of people btw.
To: Gimp-user@lists.XCF.Berkeley.EDU Date: Mon, 27 Jul 2009 18:47:26 +0100 Subject: [Gimp-user] sharpening
Norman
peter kostov
2009-07-27 21:36:07 UTC (almost 16 years ago)
sharpening
Norman
I like the results of Tools -> Gegl operation -> Unsharp mask at default values :)
G'mic toolbox (http://gmic.sourceforge.net/gimp.shtml) has an unsharp mask with more options too, but I personally prefer the more simple approach of Gegl and have failed to obtain good results with G'mic (the default values produse way to much sharpening)
Greetings, Peter
Martin Cracauer
2009-07-27 22:10:24 UTC (almost 16 years ago)
sharpening
Norman Silverstone wrote on Mon, Jul 27, 2009 at 06:47:26PM +0100:
For things like eye popping and enhancement of fur patterns the probably most popular method is unsharp mask. The default values are pretty good (although you might want to overdo the intensity and then use layer opacity to adjust later).
If you get color casts at the edges, decompose into HSV and only sharpen the V (value) channel, then recompose.
If you do partial sharpening in soft selections many people feather the selection at the edges to blend in before copying the section to a new layer for sharpening. Myself, I prefer to sharpen in a non-feathered selection and then I use the erasor with a soft brush to blend in the edges. It's like interactive feathering.
Be warned that the edge softness doesn't always react well with layer opacity adjustment, much less duplication of the sharp parts layer.
Hope this helps.
Martin
phanisvara das
2009-07-28 07:15:25 UTC (almost 16 years ago)
sharpening
are you looking for this turorial: "smart sharpening" ? URL: http://gimp.org/tutorials/Smart_Sharpening/
it's found under the GIMP tutorial section, together with tons of other useful tips, at http://gimp.org/tutorials/
phani.
Norman Silverstone
2009-07-28 08:37:46 UTC (almost 16 years ago)
sharpening
It is very similar to this, thanks.
Very helpful,thanks.
Norman
2009-09-05 09:24:32 UTC (almost 16 years ago)
sharpening
I'm trying to follow this smart sharpening tutorial from version 2.6.7. Several items in the early steps are slightly different - menu steps to decompose vary a bit, for example.
But,everything seems to work for me up to step 7, at which I cannot complete steps beyond. There must be some slight differences between 2.6.7 and the version used in the tutorial, as I cannot seem to get the select-all to show up in the sharpening thumbnail in the layers-channels, etc. dialog.
Any advice?
Thanks.
Caruso
Norman
Norman Silverstone
2009-09-05 10:01:16 UTC (almost 16 years ago)
sharpening
I had the same problem and, eventually, found just what I wanted at
http://forum.meetthegimp.org/index.php/topic,480.0.html
It works really well.
Norman
David Gowers
2009-09-05 10:02:56 UTC (almost 16 years ago)
sharpening
"The select-all"? There is no "select-all" in the layers dialog, or the channels dialog.
As far as I can see, step 7 is just saying: * Make the L layer the active layer
* make sure you have a channels dialog up * click on the 'new channel' icon and type in the name 'Sharpening mask'
This does not make too much sense to me. I think what the intent is, is to create a channel from the sharpening mask layer you already generated.
The way I would do that myself (combining the intent of steps 7 and 8), is: * Make the sharpening mask layer active * Edit->Select All (oh -- is this what you are trying to get to show up? It's in the image window, not the channels dialog.) * Edit->Copy
* create the new channel named 'sharpening mask' on the appropriate image. * make the 'sharpening mask' active
* Edit->Paste
* Click on the Anchor button (weirdly, this is in the Layers dialog, not the Channels dialog) to anchor the pasted content
phanisvara das
2009-09-05 10:05:42 UTC (almost 16 years ago)
sharpening
2.6.7.
i had the same problem and found that this procedure works for me:
--after decomposing, i go back to the original (or duplicate) image, do the edge, levels, and gaussian blur things; --select all and copy the selection to the clipboard; --then undo everything until the normal color image is visible again;
--now change to the decomposed image; --highlight the "L" layer;
--go to channels and add a new one;
--select the new channel and paste the selection still in the cliboard; --go to layers and anchor the floating selection; --go back to channels and create a selection from the new channel; --switch off visibility of the new channel and deselect it, selecting the original ones;
--go to layers, make sure "L" is selected, and apply unsharp mask; --select colors->components (or whatever it's called)->recompose; --close the (previously) decomposed image and save changes;
now the original image has the smart sharpening applied. if you don't like the result, you can undo and start over.
