Separate+ 0.5.4-beta1
Separate+ 0.5.4-beta1 Yoshinori Yamakawa 27 Jul 08:04
Yoshinori Yamakawa
2009-07-27 08:04:51 UTC (over 15 years ago)
Separate+ 0.5.4-beta1 is released. http://sourceforge.jp/projects/separate-plus/releases/41810/
Devicelink profile is supported in this release. (The separate plug-in only, icc_colorspace don't support yet)
If you want to try it, turn on "Use devicelink profile" on the Separete dialog, and choose the RGB->CMYK devicelink profile. Destination profile is not used for RGB->CMYK conversion, but it will be attached into result image.
In non-interactive mode, for example: ( plug-in-separate-full 1 img layer devlink "" FALSE FALSE 0 FALSE FALSE ) The 8th-10th parameters are ignored.
