gimp2.0pre & python
gimp2.0pre & python Przemyslaw Gawronski 12 Jan 10:03
  gimp2.0pre & python Sven Neumann 12 Jan 10:27
   gimp2.0pre & python Przemyslaw Gawronski 12 Jan 11:09
    gimp2.0pre & python Manish Singh 12 Jan 11:54
     gimp2.0pre & python Przemyslaw Gawronski 12 Jan 12:33
  gimp2.0pre & python Joao S. O. Bueno 13 Jan 14:51
2004-01-12 10:03:01 UTC (over 21 years ago)
gimp2.0pre & python
Hi, I've downloaded gimp2.0.pre, compiled (with --enable-python), but the scripcts included don't work. Is this known, or there is something wrong with my installation ?
Thanks for some information.
Przemek
2004-01-12 10:27:45 UTC (over 21 years ago)
gimp2.0pre & python
Przemyslaw Gawronski writes:
It would certainly help if you could describe more precisely how the scripts don't work.
2004-01-12 11:09:55 UTC (over 21 years ago)
gimp2.0pre & python
Dnia Mon, Jan 12, 2004 at 10:27:45AM +0100, Sven Neumann napisa?:
Yes, sorry, about leaving that out.
Here it is:
[gawron@p-gawronski gawron]$ gimp-1.3 & [1] 4311
[gawron@p-gawronski gawron]$ This is a development version of The GIMP. Debug messages may appear here.
gimp_composite: use=yes, verbose=no +mmx +sse +sse2 -3dnow -altivec -vis Traceback (most recent call last):
File "/home/gawron/lib/gimp/1.3/python/gimpfu.py", line 427, in _run extra_params = _interact(func_name) File "/home/gawron/lib/gimp/1.3/python/gimpfu.py", line 239, in _interact import gimpui
File "/home/gawron/lib/gimp/1.3/python/gimpui.py", line 15, in ? pygtk.require('2.0')
File "/usr/lib/python2.2/site-packages/pygtk.py", line 45, in require assert not sys.modules.has_key('gtk'), \ AssertionError: pygtk.require() must be called before importing gtk
I've tryied to run from the main menu:
Extras->Python-Fu->Misc->Sphere
All other python scripts endup the same way.
Manish Singh
2004-01-12 11:54:30 UTC (over 21 years ago)
gimp2.0pre & python
Here it is:
Your version of pygtk is too old, you should use at least 1.99.15, or even better 2.0.0.
I've updated the configure script to enforce this.
-Yosh
2004-01-12 12:33:11 UTC (over 21 years ago)
gimp2.0pre & python
I did as sugested, works like a charme, thankx.
Przemek
Joao S. O. Bueno
2004-01-13 14:51:36 UTC (over 21 years ago)
gimp2.0pre & python
Przemek
Hi there,
There is an issue with Python when changing from gtk 1.x to gtk 2.x - and that happens when you change from GIMP 1.2 to GIMP 2.x.
It is IMO, quite shamefull for the PyGTK guys, but is "work aroundable".
The is a file in the Python packages which says which version of GTK porgrans that use PyGTK and the GIMP Python is such a program) will use.
It is called "pygtk.pth". Locate this file in your python directories, and change its content from:
gtk-1.2
to:
gtk-2.0
When you want to run gimp 1.2.5 python scripts, you have to revert this.
The whole issue exists because the PyGTK guys (ok, not all of them, it was an individual decision) did not want to create a "gtk2" module, and kept the name of the gtk2 module as "gtk", thus breaking backwards compatibility.
Regards, JS
