Using GIMP on Netbooks?
7 of 7 messages available
Using GIMP on Netbooks? Mewshi Mewshi 22 Jun 13:36
  Using GIMP on Netbooks? David Herman 22 Jun 16:53
   Using GIMP on Netbooks? Ville Pätsi 22 Jun 17:03
    Using GIMP on Netbooks? Mewshi Mewshi 22 Jun 19:03
     Using GIMP on Netbooks? DJ 22 Jun 23:25
      Using GIMP on Netbooks? Jochen Cichon 23 Jun 08:21
       Using GIMP on Netbooks? Patrick Horgan 23 Jun 19:18
Mewshi Mewshi
2009-06-22 13:36:19 UTC (over 16 years ago)
Hello!
I just got a Lenovo S10 Netbook, with a 10" screen. The problem is, with such a small-ish screen, I can't see part of the tool windows in GIMP!
If anyone has ideas, I'm listening :)
David Herman
2009-06-22 16:53:04 UTC (over 16 years ago)
On Monday 22 June 2009, Mewshi Mewshi wrote:
Hello!
Plug into a regular monitor when wiorking, w/ a little effort you can keep your tools on the netbook and image on the monitor. You will still be limited in the output resolutions available but they are greater than that provided by the netbook.
Also remember heavy image lifting is not the intended focus of these devices, although they do an admirable job.
see ya
Ville Pätsi
2009-06-22 17:03:49 UTC (over 16 years ago)
Another thing is that netbooks have poor TFT LCD screens that aren't very good when it comes to color. Graphic design with with a predefined palette might be fine, but I wouldn't touch up photos with a netbook.
As a test I tried running Argyll CMS with my colorimeter on my Asus 1000HE display. It did all but scream in pain.
-- Ville Pätsi
Mewshi Mewshi
2009-06-22 19:03:03 UTC (over 16 years ago)
Actually, I was more hoping if there's any way I could modify the toolboxes to make things fit better.
And, yes, I realize that the colors are probably off terribly; it looks fine to me and my girlfriend (the two people who matter to me) so I don't really care.
Anyway, if anyone has any more ideas on making gimp work nicer on a netbook, I'm all ears.
Thanks, Harold Schreckengost
DJ
2009-06-22 23:25:42 UTC (over 16 years ago)
By ToolBox, you mean:
http://docs.gimp.org/2.6/en/gimp-concepts-usage.html#gimp-concepts-toolbox
I take it dragging the corners or the side to make it narrow didn't help.
Items can be removed from the ToolBox via Windows > Dockable Dialogs > Tools.
Since space is at a premium, you might want to remove Wilbur ((toolbox-wilber no)) on the ToolBox. Akkana Peck has a tip on her site. See: http://gimpbook.com/tips.html
Is it possible to work without the actual ToolBox? I think most of the items can be accessed via the Image window under Tools.
Just some thoughts. HTH
Jochen Cichon
2009-06-23 08:21:12 UTC (over 16 years ago)
Would be great (as I said in some fewer posts) to get rid of the empty image window on startup.
(like the old gimp did...)
So the old gimp did only start into the toolbox. (with a minimal menu, file, extra...)
Would be great to have that back, cos even on my desktop I mostly have that gimp toolbox somewhere at the side... and that empty window really annoys me.
Patrick Horgan
2009-06-23 19:18:53 UTC (over 16 years ago)
If you're using gimp the window isn't empty and if you're not using gimp why have it running? Note that I'm not a gimp developer because it hasn't felt like time to tackle the no doubt steep learning curve, but I REALLY appreciate them. I also really love the new UI (can we still say new after all this time?) It used to be strange and scattered, and now with the menus in the image window (whether you've loaded an image into it or not), and it staying after you exit the last image things are simpler and clearer. It's a more usual paradigm to have the menus in the window you edit things in. I used to think that I wanted to be able to dock the tools and layers on the side of the image window, but now realize that I really don't. I want maximum area for my editing, and when I need a tool or want to select a layer mask makes it appear and then makes it go away so once again I have maximum area for editing:)
Just my 2 cents;)
Patrick
annoys me.
