Pixilated sky fix and comment field unique per image?
Pixilated sky fix and comment field unique per image? DJ 19 Jun 22:39
DJ
2009-06-19 22:39:35 UTC (almost 16 years ago)
Hi Gimp-user,
1)
The blue sky is kind of pixilated in this image. http://www.fws.gov/digitalmedia/cdm4/item_viewer.php?CISOROOT=/natdiglib&CISOPTR=6008&CISOBOX=1&REC=14 How would you fix it?
2)
Is the Comment text, located at Image > Image Properties, unique per image?
I downloaded the above image and copied/pasted the download URL in the Image > Image Properties > Comment text area for documentation purposes. But then when I created a new image (File > New > Advanced Options), the comment field contained the URL and not the default text from the Preferences.
Thank you.
