Gimp Manual format.
Gimp Manual format. | John Culleton | 18 Jun 16:01 |
Gimp Manual format. | Michaela Baulderstone | 18 Jun 16:40 |
Gimp Manual format. | Ken Warner | 18 Jun 16:56 |
Gimp Manual format. | Jay Smith | 18 Jun 17:05 |
Gimp Manual format. | DJ | 18 Jun 19:20 |
Gimp Manual format. | John Culleton | 18 Jun 23:13 |
Gimp Manual format. | Sven Neumann | 18 Jun 23:26 |
Gimp Manual format. | Sven Neumann | 19 Jun 00:07 |
Gimp Manual format. | John Culleton | 20 Jun 20:10 |
Gimp Manual format. | Martin Nordholts | 20 Jun 20:17 |
Gimp Manual format. | John Culleton | 20 Jun 20:33 |
Gimp Manual format. | Jogchum Reitsma | 20 Jun 21:35 |
Gimp Manual format. | Owen | 21 Jun 00:41 |
Gimp Manual format. | Sven Neumann | 21 Jun 11:52 |
Gimp Manual format. | Jogchum Reitsma | 21 Jun 17:36 |
Gimp Manual format. | John Culleton | 14 Jul 17:11 |
Gimp Manual format. | Owen | 15 Jul 01:12 |
Gimp Manual format. | Sven Neumann | 18 Jun 23:16 |
Gimp Manual format.
Is the Gimp online manual also available in another format? Currently I am printing out the html pages a small batch at a time. That's a tedious process. A printed version or even a version in a single electronic file would save a lot of time. A printed and bound version would be handier to use than a ring binder of 8.5 x 11 pages. Once I printed out the 880 pages of the Kylander Manual but that dated back to version 1 or thereabouts. That was as I recall in a single file. Therefore I could print it out using poor man's duplexing, (even pages first, then reload the paper stack and print odds.)
Gimp Manual format.
I agree! A PDF version would be fantastic!!!! Anyone interested in the job?
-----Original Message----- From: gimp-user-bounces@lists.XCF.Berkeley.EDU [mailto:gimp-user-bounces@lists.XCF.Berkeley.EDU] On Behalf Of John Culleton Sent: Thursday, 18 June 2009 11:36 PM To: Gimp-user@lists.xcf.berkeley.edu Subject: [Gimp-user] Gimp Manual format.
Gimp Manual format.
http://html-pdf-converter.com/
PDF Converter, HTML to PDF Converter For Free
Gimp Manual format.
From: gimp-user-bounces@lists.XCF.Berkeley.EDU [mailto:gimp-user-bounces@lists.XCF.Berkeley.EDU] On Behalf Of John Culleton Sent: Thursday, 18 June 2009 11:36 PM To: Gimp-user@lists.xcf.berkeley.edu Subject: [Gimp-user] Gimp Manual format.Is the Gimp online manual also available in another format? Currently I am printing out the html pages a small batch at a time. That's a tedious process. A printed version or even a version in a single electronic file would save a lot of time. A printed and bound version would be handier to use than a ring binder of 8.5 x 11 pages. Once I printed out the 880 pages of the Kylander Manual but that dated back to version 1 or thereabouts. That was as I recall in a single file. Therefore I could print it out using poor man's duplexing, (even pages first, then reload the paper stack and print odds.)
I know nothing of the workflow that results in the current HTML manual format. It would seem to me that producing one or more other formats should come out of that same workflow. I cannot imagine the labor would be justified to do a one-time-only current-state PDF version that would be almost instantly out of date. That probably means that the authoring workflow and environment needs to be considered. This type of documentation is one of the prime beneficiaries of single-source, multiple-output authoring tools. I have not kept up on the current state of those tools and I am especially not aware of their status and capabilities in the open-source arena. However, I do know that there are a variety of approaches, each with their strengths and weaknesses.
Jay
Gimp Manual format.
Is the Gimp online manual also available in another format? Currently I am printing out the html pages a small batch at a time. That's a tedious process. A printed version or even a version in a ...
This might be cheaper than paper, ink, electricity, your time, and a potential option:
GIMP User Manual: GNU Image Manipulation Program : Photo Retouching, Image Composition and Image Authoring (Paperback) by GIMP DocumentationTeam (Author), $30.05 http://www.amazon.com/GIMP-User-Manual-Manipulation-Composition/dp/1441419322/
This was from the Gimp FAQ:
http://www.gimp.org/docs/userfaq.html#Manual
Is there a user manual?
Yes. It is available in HTML form, and in PDF.
But it seems the PDF is 2.4, not 2.6.
I'm in the same boat, so I hope I'm stepping lightly.
There are tools on Linux to convert from various formats. And Windows too. I'm think'n download the documentation, or it might already be installed as part of Gimp's help, and run it through one of these tools to create a PDF format from html.
For the raw Gimp documentation, I'd just like to mention Asciidoc. It allows you to write documents in text and process them (python) into html, docbook, pdf, and more. I've followed the google support list and there was a thread about an author using it for an OReilly book, who also created a web site. If it would help, in any fashion, the link is: http://www.methods.co.nz/asciidoc/
Gimp Manual format.
Jay
All manuals are out of date. The fact that a manual is instantly updateable does not guarantee that all sections will be fully updated concurrently with the latest stable Gimp. There are only so many skilled hands to do it. In terms of paper books I work primarily from _Grokking the Gimp_ (2000) and the newer but sill obsolete _Artist's Guide to Gimp Effects_ (2007). The html manual is the most up to date best we have at the moment, and represents a huge work effort on the part of many people.
But even within its present constraints the html manual can be improved by renaming the html files for the beginning section covered in numeric order. Some are named that way but most are not. One segment of Chapter 3, six segments of chapter 5 and two each for chapters 11 and 12 are so named. The rest have descriptive names.
An index would also help.
Gimp Manual format.
That's a question for the gimp-docs mailing-list.
Gimp Manual format.
What's wrong with http://docs.gimp.org/2.6/en/gimp-help-index.html ?
Gimp Manual format.
Indeed. The manual is written in Docbook/XML and you can get a variety of output formats from that source. If you checkout the gimp-help-2 repository from git.gnome.org (I suggest to do a shallow clone due to the immense size of the project), then you will get the Docbook/XML sources, the images and a build system that spits out HTML and optionally PDF or ODF.
Here's what I did to get a PDF version of the english user manual:
git clone --depth=0 git://git.gnome.org/gimp-help-2
cd gimp-help-2
./autogen.sh
LINGUAS=en make
LINGUAS=en make pdf-local
And to check the result:
pdfinfo pdf/en/gimp.pdf
Title: GNU Image Manipulation Program
Subject:
Keywords:
Author:
Creator: DBLaTeX-0.2.10-1
Producer: pdfTeX-1.40.3
CreationDate: Thu Jun 18 23:57:05 2009
ModDate: Thu Jun 18 23:57:05 2009
Pages: 849
Encrypted: no
Page size: 595.276 x 841.89 pts (A4)
File size: 39395416 bytes
Optimized: no
PDF version: 1.4
Gimp Manual format.
git clone --depth=0 git://git.gnome.org/gimp-help-2 cd gimp-help-2
./autogen.sh
LINGUAS=en make
LINGUAS=en make pdf-localAnd to check the result:
Title: GNU Image Manipulation Program Subject:
Keywords:
Author:
CreationDate: Thu Jun 18 23:57:05 2009 ModDate: Thu Jun 18 23:57:05 2009 Tagged: no
Pages: 849
Encrypted: no
Page size: 595.276 x 841.89 pts (A4) File size: 39395416 bytes
Optimized: no
PDF version: 1.4Sven
This is just what I was looking for! Thanks. Am I correct in assuming that setting depth=0 delivers just the latest version?
Gimp Manual format.
You get the latest version also without --depth=0, but you also get the entire history of gimp-help-2, which is huge. So unless you want the history, --depth=0 will save you vast amounts of data copying.
/ Martin
Gimp Manual format.
./autogen.sh
LINGUAS=en make
Keywords:
Author:
Pages: 849
Encrypted: no
Optimized: no
Addendum: you need to download and install DBLaTeX first. And have TeX of course.
Gimp Manual format.
./autogen.sh
LINGUAS=en make
Keywords:
Author:
Pages: 849
Encrypted: no
Optimized: no
Gimp Manual format.
./autogen.sh
LINGUAS=en make
That snippet from Sven was fantastic, thanks, worked like a charm
Seems a perfect solution, be it that in my case (Suse 11.1), the first make fails with
*** Making html for en ... /usr/bin/xsltproc \
--nonet \
--xinclude \
--stringparam l10n.gentext.default.language en \ -o html/en/ \
stylesheets/plainhtml.xsl \ xml/en/gimp.xml
I/O error : Attempt to load network entity http://docbook.sourceforge.net/release/xsl/current/xhtml/chunk.xsl warning: failed to load external entity "http://docbook.sourceforge.net/release/xsl/current/xhtml/chunk.xsl" compilation error: file stylesheets/plainhtml.xsl line 8 element import xsl:import : unable to load
http://docbook.sourceforge.net/release/xsl/current/xhtml/chunk.xsl make[1]: *** [html/en/index.html] Fout 5The URL is accessable in a browser, so that's not the problem.
Any idea what that might be?
I had no trouble, but then again, I had installed anything that looked like docbook, stylesheets into Ubuntu-9.04 when it came out, so all I can suggest is that you get all the stylesheets.
However you might be better off looking at the Makefile and seeing what it wants. I notice these things which you probably should have installed.
DBLATEX = /usr/bin/dblatex
DOCBOOK2ODF = /usr/bin/docbook2odf
XML2PO = /usr/bin/xml2po
XMLLINT = /usr/bin/xmllint
Installing those may have other dependencies that should bring your system up to date
Owen
Gimp Manual format.
--nonet \
--xinclude \
Your installation of the Docbook tools is incomplete. The make rules explicitly disable the use of non-local style-sheets (that's what --nonet does), so you need to have a complete Docbook/XML installation locally.
Gimp Manual format.
That did it.
Thanks Sven, thanks Owen!
Jogchum
Gimp Manual format.
--nonet \
--xinclude \
http://docbook.sourceforge.net/release/xsl/current/xhtml/chunk. xsl warning: failed to load external entity
"http://docbook.sourceforge.net/release/xsl/current/xhtml/chunk .xsl" compilation error: file stylesheets/plainhtml.xsl line 8 element import xsl:import : unable to load
http://docbook.sourceforge.net/release/xsl/current/xhtml/chunk. xsl make[1]: *** [html/en/index.html] Fout 5The URL is accessable in a browser, so that's not the problem.
My run seems to blow up on LaTeX code that presumes MSWIn.
I use Slackware 12.2.
Here are some of the error messages:
no support found for ifxetex
no support found for fontspec
no support found for xltxtra
no support found for fontenc
no support found for inputenc
no support found for fancybox
built-in module makeidx registered
no support found for docbook
no support found for unicode
gimp_tmp.tex:6847: Undefined control sequence \windows.
gimp_tmp.tex:6847: leading text: \nolinkurl{C:\windows\fonts}
gimp_tmp.tex:6847: Undefined control sequence \fonts.
gimp_tmp.tex:6848: Undefined control sequence \winnt.
gimp_tmp.tex:6848: leading text: \nolinkurl{C:\winnt\fonts}
gimp_tmp.tex:6848: Undefined control sequence \fonts.
gimp_tmp.tex:9385: Undefined control sequence \Documents.
gimp_tmp.tex:9385: leading
text: ...nd~Settings\[Username]\.gimp-2.6\menurc}
gimp_tmp.tex:9385: Undefined control sequence \@nil.
gimp_tmp.tex:9385: Incomplete \iffalse; all text was ignored after
line 9385.
gimp_tmp.tex: Emergency stop.
Here is my compile script, taken from Sven's post:
cd gimp-help-2
./autogen.sh
LINGUAS=en make
I can't find on my system gimp_tmp.tex referred to in the error
messages. Hence I can't patch the TeX code myself.
Gimp Manual format.
--nonet \
--xinclude \
I/O error : Attempt to load network entityhttp://docbook.sourceforge.net/release/xsl/current/xhtml/chunk. xsl warning: failed to load external entity
My run seems to blow up on LaTeX code that presumes MSWIn. I use Slackware 12.2.
Here are some of the error messages: no support found for ifxetex
no support found for unicodegimp_tmp.tex:6847: Undefined control sequence \windows. gimp_tmp.tex:6847: leading text: \nolinkurl{C:\windows\fonts} gimp_tmp.tex:6847: Undefined control sequence \fonts. gimp_tmp.tex:6847: leading text: \nolinkurl{C:\windows\fonts} gimp_tmp.tex:6848: Undefined control sequence \winnt. gimp_tmp.tex:6848: leading text: \nolinkurl{C:\winnt\fonts} gimp_tmp.tex:6848: Undefined control sequence \fonts. gimp_tmp.tex:6848: leading text: \nolinkurl{C:\winnt\fonts} gimp_tmp.tex:9385: Undefined control sequence \Documents. gimp_tmp.tex:9385: leading
text: ...nd~Settings\[Username]\.gimp-2.6\menurc} gimp_tmp.tex:9385: Undefined control sequence \@nil. gimp_tmp.tex:9385: leading
text: ...nd~Settings\[Username]\.gimp-2.6\menurc} gimp_tmp.tex:9385: Incomplete \iffalse; all text was ignored after line 9385.
You need at xetex, (tex-live xetex)
You need to follow Sven's advice above about Docbook as well
Do that and then see what residual errors you have
