Script to change color
Script to change color Michi21609 16 Jun 21:45
  Script to change color Chris Mohler 17 Jun 00:22
2009-06-16 21:45:08 UTC (almost 16 years ago)
Hi!
I want to do a simple task with a gimp-fu script but I didn't find anything in web yet.
I want to exchange the color 255 255 255 (RGB) to 254 254 254 (RGB) in a windows-bitmap. Or rather, i want to do that in MANY pictures, so it is not reasonable to do it manually... I really need a script.
Does anyone have a link to such a script, which is easy to exchange, or may anybody post the script code? :-)
Gimp: 2.6
I don't have to leran the fu-scripting right now, but I would to learn it later...
Thanks!
Chris Mohler
2009-06-17 00:22:02 UTC (almost 16 years ago)
On Tue, Jun 16, 2009 at 2:45 PM, Michael S. wrote:
Hi!
Perhaps this method:
http://www.imagemagick.org/Usage/color/#replace_draw
HTH, Chris
PS - you should consider using the mailing list directly, and not through the forum.
