Gimp tools not working
Gimp tools not working scutiform 12 Jun 12:28
  Gimp tools not working scutiform 12 Jun 12:49
   Gimp tools not working scutiform 12 Jun 13:00
   Gimp tools not working Tobias Jakobs 12 Jun 16:14
  Gimp tools not working James 12 Jun 18:07
2009-06-12 12:28:38 UTC (over 15 years ago)
I have upgraded to Ubuntu 9.04 and Gimp 2.6 was installed with it. When I started to use Gimp, none of the tools worked. I could select a tool and move it over a picture, but nothing happens. I have been using Gimp for several years on the same computer with previous versions of Ubuntu and Gimp 2.4 worked perfectly with Ubuntu 8.10. I have uninstalled and reinstalled using the Gimp site, apt-get install and Synaptic all with the same result.
Could this be a bug for my AMD chip-set? Are there some files missing from the original Ubuntu installation? Is it possible to install version 2.4 instead?
2009-06-12 12:49:39 UTC (over 15 years ago)
move
using
Just looked at .gimp folder and all the folders (brushes etc) are empty.
How do I get data into them?
2009-06-12 13:00:41 UTC (over 15 years ago)
Sorry -- That file is empty in other computers. The usr,share,gimp folders
DO have data in them. Why doesn't it work!!
Tobias Jakobs
2009-06-12 16:14:39 UTC (over 15 years ago)
Gimp saves only the user settings into the .gimp folder. If you remove it Gimp will create a new one and resets all settings to default.
Can please post a link to a screenshot, perhaps we can then see the problem better.
Tobias
James
2009-06-12 18:07:12 UTC (over 15 years ago)
Make sure you're on the right layer and the layer is not locked.
