How to slice the imgae for web
9 of 9 messages available
How to slice the imgae for web Nicholas I 22 May 08:53
  How to slice the imgae for web Michael Schumacher 22 May 10:43
   How to slice the imgae for web DJ 22 May 16:50
How to slice the imgae for web Bob Long 22 May 10:21
How to slice the imgae for web Bob Long 23 May 01:39
  How to slice the imgae for web Michael Schumacher 23 May 10:18
How to slice the imgae for web Bob Long 23 May 11:05
  How to slice the imgae for web devvv 23 May 12:30
  How to slice the imgae for web Sven Neumann 23 May 13:29
Nicholas I
2009-05-22 08:53:45 UTC (almost 16 years ago)
Hi ,
I am using gimp latest version and ubuntu os.
i don't see the slicing tool is it not available in the gimp latest version.
-Nicholas I
Bob Long
2009-05-22 10:21:56 UTC (almost 16 years ago)
----- Original Message ---
2009-05-22 10:43:39 UTC (almost 16 years ago)
Von: Nicholas I
What is the slicing tool?
DJ
2009-05-22 16:50:15 UTC (almost 16 years ago)
MS> What is the slicing tool?
Already mentioned was: Image > Transform > Guillotine
http://docs.gimp.org/2.6/en/plug-in-guillotine.html
There is also: Filters > Web > Slice
http://docs.gimp.org/2.6/en/python-fu-slice.html
Checkout the gimp registry too.
PS: The links to the GIMP documentation are broken on http://www.gimp.org/docs/ which always. The web page has links like http://docs.gimp.org/en/, but it should be http://docs.gimp.org/2.6/en/
Bob Long
2009-05-23 01:39:32 UTC (almost 16 years ago)
There is also:
To follow up, GIMP 2.6.6 for Windows does not include that (not that I expect is should, as it relies on Python); GIMP 2.6.6 included in Ubuntu 9.04 does include it.
2009-05-23 10:18:13 UTC (almost 16 years ago)
Please explain how you came to this conclusion,
especially as this is no reason for something to be missing on Microsoft Windows (Perl-based would be one, for example).
Regards, Michael
Bob Long
2009-05-23 11:05:47 UTC (almost 16 years ago)
Michael Schumacher wrote:
(referring to > Filters > Web > Slice)
Well, I'd been running 2.6.5 on Windows XP; open an image, add a couple of guides and Filters|Web shows only "Image Map..." (and "Semi-Flatten", but greyed out). So I upgrade (I did not uninstall 2.6.5) to 2.6.6 today (http://downloads.sourceforge.net/gimp-win/gimp-2.6.6-i686-setup.exe via gimp.org links). Same results.
I've never installed Python on this PC. So, am I missing something by looking in the wrong place? Are you saying you'd expect "Slice" to be there in a "standard" installation of GIMP on Windows, even without Python installed, and without installing additional plug-ins?
2009-05-23 12:30:02 UTC (almost 16 years ago)
I'm a web developer, and I never used any slicing tool, although I use GIMP mainly for my website mockups. They way I do is simple: I draw a rectangle selection over the part I need, then I press CTRL+SHIFT+C (copy visible) and then CTRL+SHIFT+V (paste the copied to a new image). Then I save the new image as .png or .jpg.
I do it that way because you don't need so many images in most cases... Also there are often color gradients in websites where you only need a 1px image that is repeated through CSS. I doubt that there is much time to spare using such slicing tools. Maybe you like this way too ;)
2009-05-23 13:29:31 UTC (almost 16 years ago)
The plug-in is part of the standard installation of GIMP on Windows. But only if you installed Python before installing GIMP.
