PCD format density?
PCD format density? John Culleton 25 Apr 19:27
  PCD format density? Chris Mohler 25 Apr 21:10
John Culleton
2009-04-25 19:27:16 UTC (almost 16 years ago)
PCD format density?
Gimp doesn't use PCD format. So I have been trying to convert a PCD image to something Gimp will use, such as tiff or jpg, using the convert program from Imagemagick. I have tried various density settings.
Is there a default density to a PCD image? If so, what is it?
Chris Mohler
2009-04-25 21:10:21 UTC (almost 16 years ago)
PCD format density?
Maybe this is helpful?
http://dsl.org/cookbook/cookbook_24.html#SEC359
Chris
