Looking for script: fade-outline.scm
Looking for script: fade-outline.scm DJ 23 Apr 03:27
  Looking for script: fade-outline.scm Kevin Cozens 23 Apr 21:08
   Looking for script: fade-outline.scm DJ 23 Apr 22:17
    Looking for script: fade-outline.scm Kevin Cozens 24 Apr 00:11
     Looking for script: fade-outline.scm DJ 24 Apr 01:09
DJ
2009-04-23 03:27:03 UTC (about 16 years ago)
Hi Gimp-user,
I was reviewing some notes I had on a tutorial for buttons. It used a script called fade-outline.scm. I couldn't find it at Gimp Registry, but I did find it at the link below:
http://linux.softpedia.com/get/Multimedia/Graphics/GIMP-SCRIPT-FUs-33171.shtml
It appears to be a package of scripts. I don't know much about it, but thought I'd pass it on.
Anyone using it?
Thank you.
Kevin Cozens
2009-04-23 21:08:14 UTC (about 16 years ago)
The fade-outline.scm script was removed from the GIMP source tree by Sven Neumann on August 15, 2007. See bug #466382 for the details http://bugzilla.gnome.org/show_bug.cgi?id=466382
DJ
2009-04-23 22:17:01 UTC (about 16 years ago)
Hi Kevin & gimp-users,
Oh wow. I wouldn't have thought to look in bugzilla for a script. So many places to go, so little time :-) lol
I'll change my notes that I jotted down from the online tutorial, and try this:
bugzilla snippet:
IMO we should simply remove the script from the menus. The functionality that it does provide can easily be achieved by feathering the selection and transferring the selection to the layer mask.
Thank you.
KC> The fade-outline.scm script was removed from the GIMP source tree by Sven KC> Neumann on August 15, 2007. See bug #466382 for the details KC> http://bugzilla.gnome.org/show_bug.cgi?id=466382
Kevin Cozens
2009-04-24 00:11:33 UTC (about 16 years ago)
The information was from the GIMP ChangLog file and not bugzilla.
DJ
2009-04-24 01:09:16 UTC (about 16 years ago)
Hi Kevin and GimpUsers
KC> The information was from the GIMP ChangLog file and not bugzilla.
OOOppps... I wouldn't have thought of that either. Argh. I thought, it's a script, go to the gimp registry, and if that doesn't work, google. There seems to be "official" scripts, and "user-developed" scripts. I thought fade-outline.scm, used in an online tutorial I had taken notes from and wanted to revisit, was the later, but it was the former. Sorry, my misunderstanding. I did check the gimp change log in the system directory, and there it was.
Thank you again.
