Moving and Resizing an existing Path
3 of 4 messages available
Moving and Resizing an existing Path DJ 15 Apr 00:39
  Moving and Resizing an existing Path David Gowers 15 Apr 01:30
115405025.20090414203513@ya... 07 Oct 20:20
  Moving and Resizing an existing Path David Gowers 15 Apr 06:26
DJ
2009-04-15 00:39:46 UTC (about 16 years ago)
I have an XCF file with saved Paths. I want to move the Paths.
I see on the Move Dialog an option, Path. But, it's a little difficult determining what I'm moving. Is there a way to make the actual Path visible while moving? I do see the rectangular box, when I click.
Also, is there a way to resize a saved Path? I did "Path to Selection" again, and I was looking for resize handles, like when using the Rectangle Selection Tool. I'd rather resized the Path, rather than the Selection, but at the moment I can't do either. :-)
Thanks much!
David Gowers
2009-04-15 01:30:18 UTC (about 16 years ago)
Why don't you make the actual path visible in the paths dialog, the same way you would make a layer visible? Though I admit, GIMP should probably make any item we are transforming temporarily visible.
Use the Scale tool; all the transform tools have the same options regarding what they effect.
David
David Gowers
2009-04-15 06:26:53 UTC (about 16 years ago)
On Wed, Apr 15, 2009 at 11:05 AM, DJ wrote:
Paths to Selection and Stroking that Selection:
I have 3 paths and I clicked "Path to Selection" while holding down the shift key. All 3 paths are now one selection. I want to outline this selection, so I go to "Edit - Stroke Selection". But only the last path I added to the Selection gets stroked.
In that case, why do you believe that the paths were added to the selection rather than replacing it?
Shift+Clicking on menu items has no special meaning. All you did was 1. replace the selection with the shape of the first path 2. replace the selection with the shape of the second path 3. replace the selection with the shape of the third path
I can do each one
individually, but the project would go quicker if all 3 paths turned into a selection would get stroked.  Am I missing something or is there a better way to do this.
There are at least 2 ways to do this: 1. Use 'Add to selection' in the Paths dialog, rather than anything else, to add them all together one at a time 2. Set a group of them visible, and use 'Merge visible paths'. Note that this may produce different results to the above, depending on exactly what behaviour you were expecting.
Experiment, see which one is appropriate.
David
