Paths Tool Problem
Paths Tool Problem City Ranch 12 Apr 04:40
  Paths Tool Problem David Gowers 12 Apr 05:15
  Paths Tool Problem Olivier Lecarme 12 Apr 08:35
City Ranch
2009-04-12 04:40:55 UTC (about 16 years ago)
Paths Tool Problem
Version:1.0 StartHTML:0000000168 EndHTML:0000002241 StartFragment:0000000471 EndFragment:0000002224
gimp 2.6.6
Laptop
Windows Vista Home Premium Service Pack 1 (build 6001)
1.60 gigahertz Intel Core Duo 64 kilobyte primary memory cache
1024 kilobyte secondary memory cache
I use the Navigation window to enlarge and move around image while using the Paths Tool.
No matter the size of the photo in height and width and kb I end up with the same problem when I am finished outlining an image in the photo. When I double click on my first anchor for the marching ants I get a double line from the left to the right side in the middle of the image. This double line can be a small as eight pixels wide to as much as two thirds of the image.
If I outline using the Paths Tool two people standing together taking up most of the frame I will get the double line usually from the right elbow of the person standing on your left to the left hip of the person standing on your right. This double line can take out any where from the chest to the knees of the people or a thin line from elbow to hip.
How can I work around this or am I doing something I should not be doing?
I have uninstalled and reinstalled gimp which did not help.
Thanks for any help.
Ben McClaran
David Gowers
2009-04-12 05:15:36 UTC (about 16 years ago)
Paths Tool Problem
gimp 2.6.6
Laptop
I suspect this is a misunderstanding on your part of the mechanics of paths. A few screenshots would help a lot if you could do that?
I presume the area in question is the area of overlap between those two paths. This is normal -- it is in fact the same mechanic that allows you to have, say, a hollow circle.
If it's not what you want, I suggest exporting to Inkscape and using the Union operator to make a path that is the union of those paths.
David
Olivier Lecarme
2009-04-12 08:35:25 UTC (about 16 years ago)
Paths Tool Problem
In order to close the path, pass in Editing mode by pressing Ctrl, and simply click on the first point. Then in order to build a selection from this path, click on the corresponding button in the Path tool options.
In fact, closing the path is not even needed, generating the selection does it automatically.
