GIMP with two monitors
test Giovanni Guasti 06 Apr 09:54
  GIMP with two monitors Giovanni Guasti 06 Apr 10:07
   GIMP with two monitors Michael J. Hammel 06 Apr 16:40
    GIMP with two monitors Giovanni Guasti 06 Apr 16:57
Giovanni Guasti
2009-04-06 09:54:15 UTC (about 16 years ago)
test
Please disregard,
gg
This email and any attachments are intended for the sole use of the named recipient(s) and contain(s) confidential information that may be proprietary, privileged or copyrighted under applicable law. If you are not the intended recipient, do not read, copy, or forward this email message or any attachments. Delete this email message and any attachments immediately.
Giovanni Guasti
2009-04-06 10:07:53 UTC (about 16 years ago)
Hi Gimp gurus!
I would need to know if it is possible to use GIMP & graphic table & multiple (two) monitors.
When I have this configuration the Gimp tool draws in the wrong position (there is an offset between the pointer position and the effect on the screen). Is it a bug? I have Gimp 2.6.6 with windows xp Thanks!
GG
Michael J. Hammel
2009-04-06 16:40:38 UTC (about 16 years ago)
Yes. I use this at home.
Oh. Windows. Don't know about that. I use Linux. However, the problem you describe (pointer offset) typically occurs when you use the Configure Extended Input Devices dialog and set the Mode for you tablet to "Window". Change this to "Screen" and this shouldn't happen.
Giovanni Guasti
2009-04-06 16:57:12 UTC (about 16 years ago)
Thanks Michael, but it does not work. The offset is function of the pointer position, it is not constant. Best regards,
GG
-----Original Message-----
From: Michael J. Hammel [mailto:mjhammel@graphics-muse.org] Sent: Monday, April 06, 2009 4:41 PM To: Giovanni Guasti
Cc: gimp-user@lists.XCF.Berkeley.EDU Subject: Re: [Gimp-user] GIMP with two monitors
