Error on install: Entry Point Not Found
9 of 10 messages available
Error on install: Entry Point Not Found SChan 02 Apr 17:56
  Error on install: Entry Point Not Found SChan 02 Apr 18:00
  Error on install: Entry Point Not Found SChan 02 Apr 18:21
   Error on install: Entry Point Not Found SChan 05 Apr 23:20
    Error on install: Entry Point Not Found Philip Ward 05 Apr 23:27
    Error on install: Entry Point Not Found Michael Schumacher 05 Apr 23:44
Error on install: Entry Point Not Found Jernej Simon?i? 02 Apr 18:27
  Error on install: Entry Point Not Found SChan 05 Apr 23:13
mailman.242926.1239028841.1... 07 Oct 20:20
  Error on install: Entry Point Not Found Gary Collins 09 Apr 13:38
2009-04-02 17:56:37 UTC (about 16 years ago)
I was previously running Gimp 2.4. I just tried installing 2.6.6. It came up with this message.
file-svg.exe - Entry Point Not Found The procedure entry point xmlNanoHTTPContentLength could not be located in the dynamic link library libxml2.dll.
What should I do?
Sara
2009-04-02 18:00:40 UTC (about 16 years ago)
P.S. I am running Gimp under Windows XP.
2009-04-02 18:21:07 UTC (about 16 years ago)
Okay, I renamed the file libxml2.dll, in my WINDOWS/System32 directory. Gimp now starts up.
I would have preferred a more helpful error message, especially as searching with Google does not find anything easily.
Jernej Simon?i?
2009-04-02 18:27:25 UTC (about 16 years ago)
This is in the FAQ:
The message comes from Windows, so there's nothing GIMP can do about it.
2009-04-05 23:13:18 UTC (about 16 years ago)
Okay, thanks for explaining.
2009-04-05 23:20:27 UTC (about 16 years ago)
Gimp
now starts up.
I have discovered that renaming the file causes Systran (a popular commercial translator) to fail to start. So now, I have to rename the file before starting Gimp, then rename the file back before starting Systran.
This is not absolutely fabulous. Is there a better way?
Philip Ward
2009-04-05 23:27:48 UTC (about 16 years ago)
how about making a dupliate of the file? and haveing both named variations?
or change the registery value that looks for the file?
phil
Gimp
now starts up.
2009-04-05 23:44:52 UTC (about 16 years ago)
File a bug with Systran. They shouldn't place arbitrary DLL files into system directories. Their own program directory is a better place for them.
HTH, Michael
Gary Collins
2009-04-09 13:38:35 UTC (about 16 years ago)
Have you tried copying the file and then renaming the copy? Seems to me that that should work...Not ideal I know, but as a workaround, should save a lot of fiddling about. /Gary
Gimp
now starts up.
