script-fu "rand" function
script-fu "rand" function Catherine Jones 21 Mar 23:10
  script-fu "rand" function Kevin Cozens 22 Mar 03:48
script-fu "rand" function Catherine Jones 22 Mar 08:36
Catherine Jones
2009-03-21 23:10:30 UTC (about 16 years ago)
When I use the "rand" function in a script-fu script that I run non-interactively from the command line, I get the exact same result every time. In other words, the command
gimp -i -b '( ...)' -b '(gimp-quit 0)'
always does the same thing (assuming the same variable inputs).
This is not the behavior I want. I'd like to be able to re-seed the random number generator so as to get randomly different results. Is this possible with script-fu? Thanks... Catherine
Kevin Cozens
2009-03-22 03:48:48 UTC (about 16 years ago)
Of course it would. You are starting a fresh copy of GIMP each time. If you want to change the seed each time you start GIMP, add '(srand (realtime))' before you call '(rand)'.
Catherine Jones
2009-03-22 08:36:21 UTC (about 16 years ago)
Thanks. That solved my problem. -- Catherine
