Tutorial help
Tutorial help gimpgump 05 Mar 14:35
  Tutorial help devvv 05 Mar 14:46
   Tutorial help gimpgump 05 Mar 20:58
2009-03-05 14:35:20 UTC (about 16 years ago)
Tutorial help
Was sure I posted yesterday....
Have been following the "hot wallpaper with flames" tutorial. My problem is that when I'm trying to remove the background, instead of beeing removed completely it turns in to a white background. The whole point is that object would be freed from the background. What have I missed? Plerase help
2009-03-05 14:46:07 UTC (about 16 years ago)
Tutorial help
hi chris!
the forums of gimpusers.com are connected to the mailing list, so you should always include a link to which tutorial you refer ;)
http://www.gimpusers.com/tutorials/hot-wallpaper-1.html
i think your problem is the missing alpha channel of the layer. right click the layer in the layers dialog and choose "add alpha channel". the you should be able to free the body from the background.
2009-03-05 20:58:19 UTC (about 16 years ago)
Tutorial help
The
hi chris!
should
should
