using Alpha Layers to change white to transparent
using Alpha Layers to change white to transparent brenton 04 Mar 19:40
  using Alpha Layers to change white to transparent saulgoode@flashingtwelve.brickfilms.com 04 Mar 21:09
2009-03-04 19:40:13 UTC (about 16 years ago)
This picture shows what I have now:
http://brentonboy.com/misc-pics/layers.png
I made the mistake of creating the image to fade to white. Now I want to use alpha transparency to have it fade to transparent, for use on non-white backgrounds. I know there must be a way to change those faded white layers into fading transparencies.
I have played with the alpha layer thing a lot, but I don't know what settings to use, and it seems not to do anything anyway.
Thanks in advance.
2009-03-04 21:09:30 UTC (about 16 years ago)
Quoting Brenton :
I would recommend merging the white layers together and then performing an Alpha To Selection on the resulting layer (hide or delete the merged layer afterwards). Then add a layermask to your background layer, initialized to the Selection with the "Invert Mask" option checked.
