Stroke with Ink Tool
1 of 5 messages available
3644709b0902260408p5356e843... 07 Oct 20:19
  Stroke with Ink Tool Alec Burgess 26 Feb 13:26
3644709b0902251434x334b2043... 07 Oct 20:19
1235601767.6002.0.camel@bender 07 Oct 20:19
49A634F4.9030603@gmail.com 07 Oct 20:19
Alec Burgess
2009-02-26 13:26:49 UTC (about 16 years ago)
copying to list
@Rob: I think you sent this just to me? - you have to use reply-ALL to get it sent to the list.
Rob Antonishen wrote:
Seems to be a sticking setting problem. I am working on the steps to repeat on my main system, windows XP with gimp 2.6.4, but managed it also in Ubuntu with gimp 2.6.1
Sometimes when you go into the stroke dialog, then change the tool in the drop list, it will not use that tool, instead using the tool showing in the drop list when the dialog is opened.
Like I said, still inconsistent, but I am trying to come up with reproducible steps
Its possible I might have had the same problem ... Initially, I thought you were saying that Stroke with Ink just did not do ANYTHING.
