Soft proofing in 2.6.5
5 of 6 messages available
Soft proofing in 2.6.5 John Culleton 23 Feb 21:12
  Soft proofing in 2.6.5 Sven Neumann 23 Feb 21:23
200902240816.07380.john@wex... 07 Oct 20:19
  Soft proofing in 2.6.5 Sven Neumann 24 Feb 21:12
   Soft proofing in 2.6.5 John Culleton 02 Mar 01:42
    Soft proofing in 2.6.5 Sven Neumann 02 Mar 07:59
John Culleton
2009-02-23 21:12:30 UTC (about 16 years ago)
I copied the standard Gimp color wheel into a png image. I loaded the image into Gimp 2.65. I tried to soft proof it using view>display and then selecting color management and color proof. There was no change in the image. In theory there should be gray bars in the image where the CMYK gamut did not cover some shades.
What more do I need to do to use soft proofing? If icc color profiles are needed how do I make them available to Gimp 2.6.5? I have various icc profiles in ~/colors for use by Scribus.
2009-02-23 21:23:03 UTC (about 16 years ago)
You can either configure GIMP for Soft Proofing in the Color Management section in the Preferences dialog, or, if you insist on doing it the hard way, use View->Display Filters and set up the display filter manually. Of course you will need color profiles. But it should be obvious where to set them, no?
2009-02-24 21:12:38 UTC (about 16 years ago)
On Tue, 2009-02-24 at 08:16 -0500, John Culleton wrote:
At this point the preferences menu under the files menu shows only the Units dialog.
Huh? The Preferences dialog is located in the Edit menu (as suggested by the GNOME HIG).
PS: Next time please reply to the list. I am not going to answer mails sent only to me.
John Culleton
2009-03-02 01:42:44 UTC (about 16 years ago)
Just checked my copy of 2.6.5 and there are preferences entries on both menus. Perhaps one could be renamed. Tomorrow I will check out the correct one.
Thanks,
2009-03-02 07:59:26 UTC (about 16 years ago)
Something is very broken about your copy of 2.6.5 then. Perhaps you managed to mix up the menu XML files of GIMP 2.4 and GIMP 2.6 ?
