Problems with Help Manual
Problems with Help Manual Chris Szabó 17 Feb 13:03
  Problems with Help Manual Sven Neumann 17 Feb 22:09
Problems with Help Manual Rlt46gem@aol.com 18 Feb 08:58
Chris Szabó
2009-02-17 13:03:42 UTC (about 16 years ago)
I really hope you can help me! I originally downloaded GIMP version 2, with the help manual, and it worked really well. Then came GIMP 2.4, and I got that. I also downloaded the Help manual. BUT, I couldn't get it to work with the program, or even separately. Two days ago I decided to do everything I could to get the help info.
1. I went to the online version. Problem is, I have a dial-up connection, so this isn't an option. 2. I found http://docs.gimp.org/ and downloaded the file.It is gimp-help-2.4.2.tar. This one I couldn't open, nor could I get it to work with the GIMP program in any way. 3. After a lot more trawling, I came to GIMPUserManual PDF. "Now, I thought, I've got it!" BUT, although it looks like a .zip file, it isn't, and ZIP won't open it.
So, here I sit with two downloaded Help Manuals, but can't even open them!
Do please tell me where to go from here!
Best Regards, Chris Szabo
Christopher Szabó
Writer/Photographer
Tel: +27-12-343-0450
Fax: +27-12-343-0450 (Ask for fax line) Cell: +27-73-899-7026
E-mail: cavszabo@netactive.co.za
Member of the Southern African
Freelance Association (SAFREA)
2009-02-17 22:09:07 UTC (about 16 years ago)
It would help a lot if you told us what operating system you are using.
Rlt46gem@aol.com
2009-02-18 08:58:13 UTC (about 16 years ago)
I have the same problem. I installed the help program that was bundled with the Gimp version I got from a magazine. But when I click on the help menu in Gimp all I get is a message that says "the Gimp user menu is not installed on my computer". What do I need to do now?
Rebecca
“Those who deny freedom to others, deserve it not for themselves.” So said Abraham Lincoln!
Totally cool web site:_ Tolerance.org_ (http://www.tolerance.org/index.jsp)
ANYTHING BEYOND THIS POINT IS ADVERTISING ADDED BY AOL WITHOUT MY PERMISSION OR CONSENT
**************A Good Credit Score is 700 or Above. See yours in just 2 easy steps!
(http://pr.atwola.com/promoclk/100126575x1218822736x1201267884/aol?redir=http://www.freecreditreport.com/pm/default.aspx?sc=668072%26hmpgID=62%26bcd=fe bemailfooterNO62)
