How to remove alpha channel?
How to remove alpha channel? Joerg Bergmann 15 Feb 09:35
  How to remove alpha channel? saulgoode@flashingtwelve.brickfilms.com 15 Feb 10:27
  How to remove alpha channel? Claus Cyrny 16 Feb 13:19
Joerg Bergmann
2009-02-15 09:35:50 UTC (about 16 years ago)
For some Latex application, I have to crop some image. I load a tiff into GIMP. It will be one gray channel only. I copy some part of the image and include it as a new image. This new image has, unfortunately for me, been added an alpha channel. There seem to be no way to remove the alpha channel or, as an alternative, to store a tiff without alpha channel. Simply spoken: I do not want alpha channels in my tiffs.
Thanks for a hint.
Joerg Bergmann
2009-02-15 10:27:38 UTC (about 16 years ago)
Quoting Joerg Bergmann :
Use the menu command "Image->Flatten" to remove the alpha channel before saving.
Claus Cyrny
2009-02-16 13:19:06 UTC (about 16 years ago)
Thanks for a hint.
You can also define a keyboard shortcut for this, so that you don't have to do it manually via the menu each time. In my Gimp 2.4.7, it can be done via "File > Keyboard Shortcuts".
HTH,
Claus
