curves spline batch
7 of 7 messages available
curves spline batch Decimator Doseven 10 Feb 15:55
  curves spline batch saulgoode@flashingtwelve.brickfilms.com 10 Feb 18:58
   curves spline batch Niels Giesen 10 Feb 19:54
curves spline batch Decimator Doseven 10 Feb 22:23
  curves spline batch Sven Neumann 10 Feb 23:11
curves spline batch Decimator Doseven 11 Feb 16:55
  curves spline batch monty 10 Jun 09:30
Decimator Doseven
2009-02-10 15:55:14 UTC (about 16 years ago)
curves spline batch
I am attempting to set up a batch that automatically runs gimp-curves-spline on a set of images. However, I have never used Scheme before and therefore am not sure why my script is returning "batch command experienced an execution error"
Here is the command I am using to call the script(via a windows .bat file)
gimp-2.6.exe -i --verbose -b "(color-curve \"C:\\gimpbatchtest\\*.tiff\")" -b "(gimp-quit 0)"
And the script itself:
(define (color-curve pattern) (let* ((filelist (cadr (file-glob pattern 1)))) (while (not (null? filelist))
(let* ((filename (car filelist)) (image (car (gimp-file-load RUN-NONINTERACTIVE filename filename))) (drawable (car (gimp-image-get-active-layer image)))) (gimp-curves-spline RUN-NONINTERACTIVE image HISTOGRAM-VALUE 3 '(0 0 64 200 128 46)) (gimp-file-save RUN-NONINTERACTIVE image drawable filename filename) (gimp-image-delete image)) (set! filelist (cdr filelist)))))
Any help will be greatly appreciated, thank you.
-Byron
2009-02-10 18:58:26 UTC (about 16 years ago)
curves spline batch
Quoting Decimator Doseven :
I am attempting to set up a batch that automatically runs gimp-curves-spline on a set of images. However, I have never used Scheme before and therefore am not sure why my script is returning "batch command experienced an execution error" :
Unfortunately, you cannot just pass a list of values to the 'gimp-curves-spline' PDB function; you must pass that list as an array of 8-bit values.
You can create such an array with code similar to the following
(let* ( (my-curve (cons-array 6 'byte)) )
(aset! my-curve 0 0)
(aset! my-curve 1 0)
(aset! my-curve 2 64)
(aset! my-curve 3 200)
(aset! my-curve 4 128)
(aset! my-curve 5 46)
(gimp-curves-spline RUN-NONINTERACTIVE image HISTOGRAM-VALUE 3 my-curve) )
Niels Giesen
2009-02-10 19:54:45 UTC (about 16 years ago)
curves spline batch
On Tue, Feb 10, 2009 at 6:58 PM,
Maybe byte-arrays where stored differently in earlier versions (I do not know), but it seems to me they are stored as vectors in GIMP 2.6.4, so is there any reason not use a literal vector (as in #(0 0 64 200 128 46)):
(equal? #(0 0 64 200 128 46) (let ((my-curve (cons-array 6 'byte))) (aset my-curve 0 0)
(aset my-curve 1 0)
(aset my-curve 2 64)
(aset my-curve 3 200)
(aset my-curve 4 128)
(aset my-curve 5 46)))
=> #t
Just wondering, Niels.
Decimator Doseven
2009-02-10 22:23:24 UTC (about 16 years ago)
curves spline batch
Ok, I have made progress. It appears that Gimp 2.6 does not like "aset!", so I had to change it to "vector-set!" to make gimp take it. Note this page stating that "aset" was deprecated back in gimp 2.4: http://www.gimp.org/docs/script-fu-update.html
Script-fu gives me much better error messages. With my current script, I get this response, which I think means null: ()
The image does not appear to have been modified at all, so there is still something wrong.
Currently, I am using this line, via script-fu, to run my script:
(color-curve "C:\\gimpbatchtest\\*.tiff")
(let* ((filename (car filelist)) (image (car (gimp-file-load RUN-NONINTERACTIVE filename filename))) (drawable (car (gimp-image-get-active-layer image)))) (let* (
(my-curve (make-vector 6 'byte)) )
(vector-set! my-curve 0 0) (vector-set! my-curve 1 0) (vector-set! my-curve 2 208) (vector-set! my-curve 3 17) (vector-set! my-curve 4 255) (vector-set! my-curve 5 255) (gimp-curves-spline image HISTOGRAM-VALUE 6 my-curve) )
Thanks in advance.
-Byron
2009-02-10 23:11:21 UTC (about 16 years ago)
curves spline batch
You are passing the image ID to the gimp-curves-spline procedure but it expects the drawable ID.
Decimator Doseven
2009-02-11 16:55:12 UTC (about 16 years ago)
curves spline batch
----- Original Message ----
Cc: gimp-user@lists.XCF.Berkeley.EDU Sent: Tuesday, February 10, 2009 4:11:21 PM Subject: Re: [Gimp-user] curves spline batch
The script is now working. I fixed the issue you mentioned, and also found that I needed to change the command I was using to call the script.
The windows batch command I am using to call the script is now: gimp-console-2.6.exe -i --verbose -b "(color-curve \"C:\\gimpbatchtest\\*.tiff\")" -b "(gimp-quit 0)"
(let* ((filename (car filelist)) (image (car (gimp-file-load RUN-NONINTERACTIVE filename filename))) (write filename)
(vector-set! my-curve 0 0) (vector-set! my-curve 1 0) (vector-set! my-curve 2 208) (vector-set! my-curve 3 17) (vector-set! my-curve 4 255) (vector-set! my-curve 5 255) (gimp-curves-spline drawable HISTOGRAM-VALUE 6 my-curve) )
Again, thanks for all the help, I was utterly clueless before.
-Byron
2011-06-10 09:30:14 UTC (almost 14 years ago)
curves spline batch
To: Decimator Doseven
-Byron
Hello friends,
I have many images amd I want to apply a curve to all these images in Gimp. How to do that? Please help me.. Thanks.
