GIMP 2.6.4 RPMs for Fedora 10, and 8
ANNOUNCE: GIMP 2.6.4 Sven Neumann 01 Jan 19:53
  GIMP 2.6.4 RPMs for Fedora 10, and 8 Johan Vromans 02 Jan 22:12
   GIMP 2.6.4 RPMs for Fedora 10, and 8 Johan Vromans 03 Jan 18:08
    GIMP 2.6.4 RPMs for Fedora 10, and 8 Johan Vromans 08 Jan 12:44
2009-01-01 19:53:20 UTC (over 16 years ago)
Happy New Year!
The GIMP developers welcome you in the new year with the fourth bug-fix release in the stable GIMP 2.6 series. The source can be downloaded from ftp.gimp.org. Binary packages for the various supported platforms should become available soon; please check at http://gimp.org/downloads/
Overview of Changes from GIMP 2.6.3 to GIMP 2.6.4 =================================================
* Bugs fixed:
565223 – Perspective transformation jagged edges / comb effect 563985 – jpg save dialog: "cancel" is treated like "commit" for settings
564087 – Using clone tool on a layer with a part out of canvas causes crashes
564593 – crash when the drawable is changed while a color tool is active
564869 – GIMP crashes on selecting Tools->GEGL operation 565138 – python-fu-foggify does not check if image is in rgb mode 563130 – Hue selection mode does not cross the 0-360 degrees line 563179 – Scrollbars not resized when we extend the canvas size 562459 – PF_PALETTE: 'TypeError' when used in a plugin that is registered in
562427 – Compilation with --as-needed 562386 – PF_SLIDER and PF_SPINNER 'Step' values do not change consistently...
562366 – Default image dimensions are not correctly transferred in the file/new dialog box 561899 – GIMP can't save to mounted filesystem if file exists
* Updated translations:
Greek (el) Hindi (hi)
Hungarian (hu)
Italian (it)
Japanese (ja)
Korean (ko)
Slovenian (sl)
Swedish (sv)
Tamil (ta)
Simplified Chinese (zh_CN)
Users and distributors are also encouraged to update GEGL to version 0.0.22, which has been released yesterday. The new GEGL release not only provides some nice speedups, it also features a new vector path representation infrastructure. This will eventually become used in GIMP to provide support for editable vector objects.
Johan Vromans
2009-01-02 22:12:12 UTC (over 16 years ago)
I've made a complete set of RPMs available for Fedora 10, and 8.
DISCLAIMER: They work for me. Your mileage may vary.
Fedora 10:
Note that you don't need the devel and debuginfo RPMs for normal use.
http://www.squirrel.nl/pub/xfer/gimp-2.6.4-1jv.fc10.i386.rpm http://www.squirrel.nl/pub/xfer/gimp-debuginfo-2.6.4-1jv.fc10.i386.rpm http://www.squirrel.nl/pub/xfer/gimp-devel-2.6.4-1jv.fc10.i386.rpm http://www.squirrel.nl/pub/xfer/gimp-libs-2.6.4-1jv.fc10.i386.rpm http://www.squirrel.nl/pub/xfer/gimp-help-browser-2.6.4-1jv.fc10.i386.rpm
Fedora 10, Source RPMs:
http://www.squirrel.nl/pub/xfer/gimp-2.6.4-1jv.fc10.src.rpm
Fedora 8:
Fedora 8 requires an update to GLib2, babl and gegl.
WARNING: Installing the new glib2 will make it impossible to upgrade your Fedora kernel! This is a known bug (not mine). So before upgrading your Fedora kernel, downgrade glib2 to its original version!
http://www.squirrel.nl/pub/xfer/babl-0.0.22-1jv.fc8.i386.rpm http://www.squirrel.nl/pub/xfer/babl-debuginfo-0.0.22-1jv.fc8.i386.rpm http://www.squirrel.nl/pub/xfer/babl-devel-0.0.22-1jv.fc8.i386.rpm http://www.squirrel.nl/pub/xfer/gegl-0.0.18-1jv.fc8.i386.rpm http://www.squirrel.nl/pub/xfer/gegl-debuginfo-0.0.18-1jv.fc8.i386.rpm http://www.squirrel.nl/pub/xfer/gegl-devel-0.0.18-1jv.fc8.i386.rpm http://www.squirrel.nl/pub/xfer/gimp-2.6.4-1jv.fc8.i386.rpm http://www.squirrel.nl/pub/xfer/gimp-debuginfo-2.6.4-1jv.fc8.i386.rpm http://www.squirrel.nl/pub/xfer/gimp-devel-2.6.4-1jv.fc8.i386.rpm http://www.squirrel.nl/pub/xfer/gimp-libs-2.6.4-1jv.fc8.i386.rpm http://www.squirrel.nl/pub/xfer/gimp-help-browser-2.6.4-1jv.fc8.i386.rpm http://www.squirrel.nl/pub/xfer/glib2-2.18.2-1jv.fc8.i386.rpm http://www.squirrel.nl/pub/xfer/glib2-debuginfo-2.18.2-1jv.fc8.i386.rpm http://www.squirrel.nl/pub/xfer/glib2-devel-2.18.2-1jv.fc8.i386.rpm http://www.squirrel.nl/pub/xfer/glib2-static-2.18.2-1jv.fc8.i386.rpm
Fedora 8, Source RPMs:
http://www.squirrel.nl/pub/xfer/babl-0.0.22-1jv.fc8.src.rpm http://www.squirrel.nl/pub/xfer/gegl-0.0.18-1jv.fc8.src.rpm http://www.squirrel.nl/pub/xfer/gimp-2.6.4-1jv.fc8.src.rpm http://www.squirrel.nl/pub/xfer/glib2-2.18.2-1jv.fc8.src.rpm
Happy gimping,
-- Johan
Johan Vromans
2009-01-03 18:08:25 UTC (over 16 years ago)
Johan Vromans writes:
These kits contain a build error due to a known bug (not mine). This bug could lead to Gimp crashes when trying to import PDF documents.
Please use the corrected kits, with release "2jv", instead.
Fedora 10:
http://www.squirrel.nl/pub/xfer/gimp-2.6.4-2jv.fc10.i386.rpm http://www.squirrel.nl/pub/xfer/gimp-debuginfo-2.6.4-2jv.fc10.i386.rpm http://www.squirrel.nl/pub/xfer/gimp-devel-2.6.4-2jv.fc10.i386.rpm http://www.squirrel.nl/pub/xfer/gimp-libs-2.6.4-2jv.fc10.i386.rpm http://www.squirrel.nl/pub/xfer/gimp-help-browser-2.6.4-2jv.fc10.i386.rpm
http://www.squirrel.nl/pub/xfer/gimp-2.6.4-2jv.fc10.src.rpm
Fedora 8:
http://www.squirrel.nl/pub/xfer/babl-0.0.22-1jv.fc8.i386.rpm http://www.squirrel.nl/pub/xfer/babl-debuginfo-0.0.22-1jv.fc8.i386.rpm http://www.squirrel.nl/pub/xfer/babl-devel-0.0.22-1jv.fc8.i386.rpm http://www.squirrel.nl/pub/xfer/gegl-0.0.18-1jv.fc8.i386.rpm http://www.squirrel.nl/pub/xfer/gegl-debuginfo-0.0.18-1jv.fc8.i386.rpm http://www.squirrel.nl/pub/xfer/gegl-devel-0.0.18-1jv.fc8.i386.rpm http://www.squirrel.nl/pub/xfer/gimp-2.6.4-2jv.fc8.i386.rpm http://www.squirrel.nl/pub/xfer/gimp-debuginfo-2.6.4-2jv.fc8.i386.rpm http://www.squirrel.nl/pub/xfer/gimp-devel-2.6.4-2jv.fc8.i386.rpm http://www.squirrel.nl/pub/xfer/gimp-libs-2.6.4-2jv.fc8.i386.rpm http://www.squirrel.nl/pub/xfer/gimp-help-browser-2.6.4-2jv.fc8.i386.rpm http://www.squirrel.nl/pub/xfer/glib2-2.18.2-1jv.fc8.i386.rpm http://www.squirrel.nl/pub/xfer/glib2-debuginfo-2.18.2-1jv.fc8.i386.rpm http://www.squirrel.nl/pub/xfer/glib2-devel-2.18.2-1jv.fc8.i386.rpm http://www.squirrel.nl/pub/xfer/glib2-static-2.18.2-1jv.fc8.i386.rpm
http://www.squirrel.nl/pub/xfer/babl-0.0.22-1jv.fc8.src.rpm http://www.squirrel.nl/pub/xfer/gegl-0.0.18-1jv.fc8.src.rpm http://www.squirrel.nl/pub/xfer/gimp-2.6.4-2jv.fc8.src.rpm http://www.squirrel.nl/pub/xfer/glib2-2.18.2-1jv.fc8.src.rpm
Happy gimping,
-- Johan
Johan Vromans
2009-01-08 12:44:22 UTC (over 16 years ago)
Fedora is catching up quickly. GIMP 2.6.4 is now available from the official Fedora (testing) F10 and F9 repositories:
# yum --enablerepo=updates-testing update gimp
-- Johan
