Having serious problems with profiling my monitor
Having serious problems with profiling my monitor Leonard Evens 13 Dec 03:30
Having serious problems with profiling my monitor Leonard Evens 13 Dec 16:22
Leonard Evens
2008-12-13 03:30:44 UTC (over 16 years ago)
Last year, I managed to profile my Samsung 226CW monitor using an Eye-One LT under Fedora 7 and the argylcms programs. When I told gimp what the display profile was, the results looked plausible. At that time I was using an early version of gimp 2.4.
But my monitor dimmed somewhat, and I wanted to redo the calibration/profiling. But it doesn't seem to be working. I also tried the same thing with a laptop running Ubuntu 8.04, and had similar problems.
The process produces a calibration (look up table) which is loaded into the video card and also a profile which a program such as gimp can use to tell the display how to interpret colors. There are two ways to tell gimp about the display profile, but it doesn't seem to matter which I use. What happens on both machines is that gimp seems to be negating the calibration (look up table) in the video card and then perhaps applying some profiling to the result. So what I get with a gray scale is the whatever tint the screen had without the look up table loaded; red-magenta for the Fedora machine and blue-cyan for the laptop display.
So either I keep doing something entirely idiotic, or gimp color management is doing the wrong thing. The versions of gimp I've been having this problem with are 2.4% and up. My current Fedora version is 2.6.3.
Supposedly Eye of Gnome can also use a display profile, and it in fact it doesn't show such an effect. The gray scales look plausible, but they might anyway, just with the calibration loaded in the video card and no profiling. But, if Eye of Gnome allows for color management, I would expect it to say something about it and possibly allow some configuration, and I can't see any indication that it is doing that.
Is there some other method independent of gimp to check whether the profiling is working?
Any suggestions would be appreciated.
Leonard Evens
2008-12-13 16:22:26 UTC (over 16 years ago)
I've since discovered that inkscape also has color management. It behaves the same way, so the problem is not specifically a gimp problem. It could be a problem with lcms, argyllcms, my measurement devices (although it seems unlikely they are both failing the same way), or the way I am going about making the profiles. With respect to the latter, I've tried a variety of approaches, and the phenomena occur both with my Smasung226W on a Fedora desktop and an Ubuntu laptop using its screen.
As I noted above, the problem seems to be that the profile is overcorrecting the calibration lut loaded in the video card, thus moving colors back towards the uncalibrated monitor. And that means a red-magenta tint for one machine and a blue-cyan tint for the other.
