Gimp update and script-fu doesn't work
9 of 9 messages available
Gimp update, script-fu and other problem Adam Tkocz 09 Dec 15:39
  Gimp update, script-fu and other problem John Coppens 09 Dec 17:35
   Gimp update, script-fu and other problem Adam@storm 09 Dec 20:16
    Gimp update, script-fu and other problem Sven Neumann 09 Dec 21:32
     Gimp update and script-fu doesn't work Adam@storm 12 Dec 11:19
      Gimp update and script-fu doesn't work saulgoode@flashingtwelve.brickfilms.com 12 Dec 16:19
       Gimp update and script-fu doesn't work Adam@storm 12 Dec 18:47
  Gimp update, script-fu and other problem Chris Mohler 09 Dec 19:25
   Gimp update, script-fu and other problem Adam@storm 09 Dec 20:30
Adam Tkocz
2008-12-09 15:39:38 UTC (over 16 years ago)
I am Gimp fan. Actually - I was. Till last weekend. I decide to reinstall my WinXP system. Before reinstall I used GIMP 2.2.10+GTK. But why should I not choose at the moment newst version of GIMP?
Download GIMP 2.6.3 (no GTK needed) and... disaster. 1) Open existing jpg image. Image is hidden behind current window, lot of clicking to show image. Unbelievable... 2) I make some corrections to colour, geometry, croping. I think they change layout off buttons in some dialogs - before button "OK" was always in right/down corner, "Cancel" was next... like here: http://docs.gimp.org/2.6/pl/gimp-tool-levels.html. OK, lets say I should read button description before hit. 3) I'm ready to finish and save a job. Apply my Script-Fu (flatten image, resolution, sharpen) and... My script doesnt work!
That's enough for me. Download Gimp 2.2.10 + GTK, uninstal 2.6.3, instal 2.2.10. I feel good now - windows, buttons, behaviour seems OK. Open jpg, make correction, run script-fu (done!!!!), now just save and... crash... once it is no problem. Try again. I do nothing, just try to save and close image. No, it doesn't work. Gimp crashes again.
OK. Back to 2.6.3. I have to do my job. Crying, but working. 2 weeks ago it took me 30 minutes to tune 20-30 images. I do it every day. Now it takes me more than one hour and I get headache every day.
Any ideas?
I'm not power user. Just using Gimp for 5 years. 2 or 3 years before I create my first and only Script-Fu. The team (my laptop, system, gimp, script-fu and me) was working perfect. But not today. Help me, please :)
Adam
John Coppens
2008-12-09 17:35:37 UTC (over 16 years ago)
Try to go to Edit | Preferences (not File | Preferences - somewhat confusing) and change Window Manager Hints to 'normal window'. But I do believe there is an issue with the windows under Windows.
No help here. I didn't feel any difference...
There was a larger change in the way Sript-Fu works between 2.2.x and 2.4.x. I had to rework my scripts too - the changes aren't too complicated to add. Check this:
http://gimp.org/docs/script-fu-update.html
BTW, going back to (or staying with) and older version is hardly a threat. You're just missing out on all the great new things the GIMP people work hard to add.
John
Chris Mohler
2008-12-09 19:25:12 UTC (over 16 years ago)
On Wed, Dec 10, 2008 at 8:39 AM, Adam Tkocz wrote: [...]>
As mentioned before, change the preferences - or just press "tab" to hide the dialogs when you're not using them.
I did not notice this either - but "Alt-O" should confirm most dialogs.
Yes - there have been changes - if you post your script-fu here, someone might help you update it.
Chris
Adam@storm
2008-12-09 20:16:23 UTC (over 16 years ago)
John Coppens said the following on 2008-12-09 17:35:
Well, thx John. I've just tried some "combination" and the problem seems to be solved. I will be sure tomorrow at the office - at home I try it on images on local HD. The problem appeared at the office, where I usually work on images saved to linux server volumes. But now I have new hope and some "how to" directions :)
Well, there is no chance to help. I just have to change or modify some fixed behaviours. It will be easier to understand if U will know, that last 5 years I made about 30'000 pictures and maybe 100'000 simple operations. I REMEMBER that "Ok" button is in Right/Down Corner. In G 2.6.3 in this corner is "Cancel" button. So... after applying levels, curves, resolution or so... I just confirm operation by moving pointer over the right/down corner button, click and... "play it again, Sam" :D
But trully it is not big matter. After next 5 years I will move mouse to another button, and they will back to "old config" ;)
Yeah, this is proper info. Thanks. I need few days to refresh my knowledge about script-fu, but I see that there is important difference in using "let" operator and generally they change variables settings. I need one day and fresh brain and maybe I will manage with it. Today is late here and... I'm tired a bit.
U R Right. But old guys (me?) sometimes are not quick and clever enought to follow all changes.
Anyway. Thanks for really BIG help.
Adam@storm
2008-12-09 20:30:57 UTC (over 16 years ago)
Chris Mohler said the following on 2008-12-09 19:25:
Yes, I applied John's advice and it seems OK. But it is not dialog matter, but Windows Explorer window (file list in folder). Maybe tomorrow I will be able to re-call the problem and make screenshot wich will explain it better than my poor english.
Alt-0 (or sometimes Enter) when U use keybord to confirm. In some cases it is faster to use keybord, in some cases is faster to use mouse. But it is not big matter. I just wonder why? Why somebody change the buttons layout. Leaving buttons untouched costs nothing, so why did they put so big time to change the laayout?
OK, thanks. Tomorrow I will check update info, than I post my script-fu here and ask some question.
A.
2008-12-09 21:32:21 UTC (over 16 years ago)
The button order follows the system preferences (since GIMP 2.4). The UI designers of your operating system have chosen to place the confirmative button leftmost. GIMP, or rather GTK+, follows this preference and places dialog buttons according to the rules that all applications on your system should obey. You could of course change this by setting the "gtk-alternative-button-order" property in your gtkrc.
That's why we have release notes with every major release:
http://gimp.org/release-notes/gimp-2.4.html http://gimp.org/release-notes/gimp-2.6.html
Adam@storm
2008-12-12 11:19:09 UTC (over 16 years ago)
> Yes - there have been changes - if you post your script-fu here, > someone might help you update it. >
Okay, pasted script lost text formating in e-mail. So I put it here:
http://ak-studio.com.pl/adam/gimp/FinishJob.scm and here:
http://ak-studio.com.pl/adam/gimp/FinishJob.txt
I need some help. First off all - how to modify this script to run properly in new enviroment (error msg: unbound variable...). I suppose the probblem is in set! operator in few lines on beginning of script.
When script was working (2.2.10) it saved me lot of time
Another question is "How to save opened jpg image" at the end of script. I've tried to do it by myself, but after one month I gived up. Only thing I can do is read file name. Nothing more
My everyday work is: 1) double click on existing .jpg file 2) make some retouching on picture, fix colors, geometry etc 3) when image is ready I would like script to do: a) scale image to 400 pxl height (perfect for target www) b) sharpen image (factor 40 - is great for my cameras) c) flatten image (than is ready for save .jpg) d) save file, exactly save, not save As - raw copy is still saved on camera flash card
e) close image
If somebody can help me I will be grateful to
TIA
2008-12-12 16:19:50 UTC (over 16 years ago)
Quoting "Adam@storm" :
Updated script:
http://flashingtwelve.brickfilms.com/GIMP/Scripts/Temp/Reworked-FinishJob.scm
I believe the most significant problem you were experiencing is that the action of flattening your image results in a newly created layer and all the original layers disappear; i.e., the original "Drawable" value that you were using in your 'file-jpeg-save' call was no longer valid after the script flattened the image.
e) close image
It is not possible to perform step 3e) -- scripts can only close images which they themselves open or create. Images that are opened or created from the menus must be closed from the menus.
The updated script will result in the image being marked as saved, so that closing the image does not generate a warning about losing changes. I am not entirely comfortable about doing this because not ALL image changes are saved with the JPEG format and closing your image after running the script will result in the loss of some information -- e.g., any channels or paths you've created, as well as the degradation of the picture owing to JPEG's lossy compression. Nonetheless, given your work flow, it seems appropriate as long as you remain aware of this limitation. If you should prefer to still be warned about losing data then remove the line which calls 'gimp-image-clean-all'.
Adam@storm
2008-12-12 18:47:28 UTC (over 16 years ago)
saulgoode@flashingtwelve.brickfilms.com said the following on 2008-12-12 16:19:
Updated script:
Great!!! It works perfect 4 me! Big thanks :)
It is dificult to say.. I have seen syntax error, or... no action, but I believe U R right.
Lets say if it is impossible than I have to find a benefit... think... think... well, there is benefit: I have "undo" working and if something is wrong with a picture (i.e to heavy sharpen) I can go step back and make all things manually. Kind of final check out. In this point it will be better when displayed image is viewed 100% (1:1). It is one command... but I do not remember...
Your notes are very important, thank U. But I know the limitation of .jpg files. This way I make just for one puprpose: network preview of real estate, for example:
http://www.burg.com.pl/mieszkanie/sprzedaz/59192/
For printed matters I can work one or two (or more) hours with each image and no script is necessary :)
One more time - thanks.
Adam.
